Throttle Body Repair - Ford Truck Enthusiasts Forums
Old 01-29-2011, 01:38 PM
SCEPTRE2000 SCEPTRE2000 is offline
SCEPTRE2000 is starting off with a positive reputation.
My mechanic said the throttle body on my F-350 needs replacing. The CEL gives off a code indicating air leaks in the body. I'm wondering if it can be repaired or if I can just clean it using a TB cleaning solution. Please help---really need some advice!!
Old 01-29-2011, 01:45 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
What codes are you getting? There is no clear-cut code that indicates the throttle body is leaking. IMHO find a new mechanic.
Old 01-29-2011, 04:10 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The only place it could be leaking air would be around the shaft for the butterflies, or at the mating gasket to the intake. If you do need another one I suggest visiting a local junkyard.
Tries to die when COLD oneowner83 Explorer, Sport Trac, Mountaineer & Aviator 6 02-04-2014 04:13 PM
Disabled / faulty check engine light sgtscrounge 1997 - 2003 F150 2 09-29-2010 08:55 PM
code 0401 tsg2397 1997 - 2003 F150 2 09-28-2010 09:50 PM
5.0L - throttle body issues K2JJB Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 03-16-2005 05:25 AM
Replacing Plenum Gasket Herby 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 12-10-1999 02:22 AM
Tags
1997, 2006, body, f250, fix, ford, repair, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
