5.0 propane conversion
Old 01-28-2011, 08:07 PM
harvy's Avatar
harvy
harvy is offline
I'm starting out with a stock 1996 ford bronco to do a propane re-power. i just got a 289 2v intake manifold to go with the 225 mixer and model e regulator that i had.
Should I deck the heads when change out the intake?
What's the max that they could be decked and what compression ratio would i end up with?
thanks in advance
Old 01-29-2011, 09:59 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
You posted in a diesel forum. I moved the thread here, and you should get more of a response from other gassers........
Old 01-31-2011, 09:24 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
You going straight lp or bifuel?
Old 01-31-2011, 12:16 PM
harvy's Avatar
harvy
harvy is offline
straight propane
Old 01-31-2011, 12:24 PM
gasman6674's Avatar
gasman6674
Hope you have a big motor fuel tank. With a Bronco there is not a lot of room to mount a tank legally.
You can up your compression and change your timing curve to optimize for lp I will see if I can track down the info or some links for you. A 225 is a little on the small size I would recommend a ca300 or a ca425 especially if your going to up-power your 302
Old 01-31-2011, 12:41 PM
gasman6674's Avatar
gasman6674
Give these guys a call they can answer your engine questions
Carb and Turbo System Shakopee MN 952-445-3910
Old 01-31-2011, 10:06 PM
harvy's Avatar
harvy
harvy is offline
i'm not looking for high hp numbers or to bug those dudes at work.
on the other hand i do have a model 300 laying around
Old 02-01-2011, 08:19 AM
gasman6674's Avatar
gasman6674
They are a Impco equipment distributor they get these questions all the time.
Sdean
03-13-2016 06:23 PM
billy-buck
16
05-05-2014 02:15 PM
The_Relic
17
03-09-2012 11:48 PM
69F250CrewCab4x4
23
12-04-2011 10:57 PM
SillyValleyF250
07-23-2008 08:04 PM
Quick Reply: 5.0 propane conversion
