Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-28-2011, 08:07 PM
harvy's Avatar
harvy harvy is offline
Garage is empty, add now
harvy is starting off with a positive reputation.
5.0 propane conversion
I'm starting out with a stock 1996 ford bronco to do a propane re-power. i just got a 289 2v intake manifold to go with the 225 mixer and model e regulator that i had.
Should I deck the heads when change out the intake?
What's the max that they could be decked and what compression ratio would i end up with?
thanks in advance
__________________
1985 F350 4x4 with a 6.9 and T-19
  #2 (permalink)
Old 01-29-2011, 09:59 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
You posted in a diesel forum. I moved the thread here, and you should get more of a response from other gassers........
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 01-31-2011, 09:24 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
You going straight lp or bifuel?
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #4 (permalink)
Old 01-31-2011, 12:16 PM
harvy's Avatar
straight propane
__________________
  #5 (permalink)
Old 01-31-2011, 12:24 PM
gasman6674's Avatar
1996 Ford F-350
Hope you have a big motor fuel tank. With a Bronco there is not a lot of room to mount a tank legally.
You can up your compression and change your timing curve to optimize for lp I will see if I can track down the info or some links for you. A 225 is a little on the small size I would recommend a ca300 or a ca425 especially if your going to up-power your 302
__________________
Jim England
  #6 (permalink)
Old 01-31-2011, 12:41 PM
gasman6674's Avatar
1996 Ford F-350
Give these guys a call they can answer your engine questions
Carb and Turbo System Shakopee MN 952-445-3910
__________________
Jim England
  #7 (permalink)
Old 01-31-2011, 10:06 PM
harvy's Avatar
i'm not looking for high hp numbers or to bug those dudes at work.
on the other hand i do have a model 300 laying around
__________________
  #8 (permalink)
Old 02-01-2011, 08:19 AM
gasman6674's Avatar
1996 Ford F-350
They are a Impco equipment distributor they get these questions all the time.
__________________
Jim England
Tags
1987, 29, 351c, 50, 67, 89, bronco, conversion, convert, diesel, engine, flathead, ford, lp, propane, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
