How do I remove mouldings and graphics
Old 01-29-2011, 07:14 AM
brcrk's Avatar
brcrk
brcrk is offline
Question How do I remove mouldings and graphics
I am fixin to start my body prep work in order to get it ready for paint. How do I take these mouldings, graphics and emblems (like the F150 emblem and other items illustrated by the arrows) Are they stuck on with tape? Will I have to use a razor or can I use a heat gun to get the graphics off?
Thanks
Old 01-29-2011, 08:34 AM
Sand_Man's Avatar
Sand_Man
Sand_Man is offline
I use a heat gun and a plastic scraper with very good results. Just heat the plastic emblems while applying pressure with the scraper and they should come off very cleanly with no leftover tape. If there is a touch of tape, then you can either carefully re-heat it or use a little PPG wax and grease remover, both work well. As for the graphics, as long as they are not buried under clear a little heat and patience will work there as well. You just need to lift one edge to get your fingernail under, then pull back, not up and it should stay in one piece to allow you to get it off cleanly. Hope this helps!
Old 01-31-2011, 10:16 PM
Chaosracing's Avatar
Chaosracing
Chaosracing is offline
For removing the emblems, just like Sand_man said, a heat gun and plastic scraper will work. Just becareful of how much heat you apply. You could also do the same to the grafix, or get a adhesive eraser for a drill. You might need one for the mouldings and emblems anyway. Using the grease and wax remover will work, but also take a long time to.
Graphic Removal Products
Old 02-04-2011, 10:33 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
For adhesive-backed emblems, I use some strong fishing line with each side tied securely around a dowel... Basically, it's a "garrote"... a tool used to strangle . Ya just drag the line through. EZ.
To remove the remaining adhesive, I use "Goof-Off". Works great. Wash it off thoroughly and reapply body wax afterwards.
Decal removal? Careful use of a heat gun and a non-metallic scraper - like plexiglass.
F100Trucker
21
12-28-2013 02:03 PM
PapaBearYuma
03-14-2012 09:10 PM
nut1605
1999 to 2016 Super Duty
06-12-2007 09:17 PM
sarigbuilder
Appearance & Dress-Up
10-03-2006 11:40 PM
Quick Reply: How do I remove mouldings and graphics
