C6 problem
C6 problem
Helping a friend on a 51 ford sedan. 429 C6. Transmission has been built. Problem is, got it in car hooked up drive shaft. Car will roll forward in neutral but won't roll back. The guy that built the tranny said he checked it when he finished and it would turn both ways. Any suggestions? Thanks, Steve
I had a few ideas had it been with the engine running. With engine off the only thing I can think of is that the parking pawl is not fully retracting when it is shifted out of Park.
maybe disconnect the driveshaft at the axle and try turning it by hand (after shifting out of park a few times), make sure it turns in the forward direction and then try turning it in reverse and see if you can feel what is happening.
is the torque converter still on the trans while u have tried it since it has been out? when i did mine, the input shaft would turn fineand the yolk would only turn one way. when i put the converter on it wouldnt spin. come 2 find out that when u assemle the pump assembly, its best to put it together on the torque converter itself. after doing this, it turned fine in one direction and kinda stiff in the other. but once it was in the truck, it works just fine now.
