No Heat in Cab
No Heat in Cab
Hi all...new to this site but enjoying all the info already.
Hoping for some help with 2007 F250 6.0L, with electronic temp control
Truck has intermittent no heat in the cab
Thermostat replaced
Coolant temp good
vacuum ok as all vents work
coolant level full
problem started only at idle now happening while driving
outside temp is -30F, any help is appriciated
Thermostat replaced
Coolant temp good
coolant level full
I have a hand vacuum pump that I use for bleeding the brakes and testing vacuum-powered components on the vehicle. I bought it at Al's, before it became Schuck's, before it became O'Riely's... anyway, it wasn't expensive and it has a guage. You can try to operate the heater water flow valve with a hand pump and see how much vacuum it takes to trip it. You can then hook up the pump to your vacuum line with the engine running and read how much vacuum you have. I did this to my truck and fixed the heater, the brake-boost, the 4X4-shift-on-the-fly, and I think the turbo... but I'm still learning my truck.
thermostat only goes in one way. one piece unit, thermostat with housing.
i am leaning towards heater core plugging up as i had the dash apart today and all blend doors and air ducting works fine.
used compressed air and blew threw the core... heat is back for right now.
i will flush the cooling system once to warms up a bit.
will keep everyone posted
Balderman72
6.4L Power Stroke Diesel
02-03-2016 11:30 PM
Coneynew
16
01-08-2007 12:09 AM
