Why Did Feedback Carburetors Lose to Electronic Fuel Injection?
#61
It will have better fuel atomization.
FYI, comparing like for like:
85 F-150, 2WD, 3-speed auto, feedback carb: 13mpg city, 14mpg freeway, 15.5 tons CO2
85 F-150, 2WD, 3-speed auto, EFI: 14mpg city, 16 mpg freeway, 13.3 tons CO2.
Source: fueleconomy.gov.
#62
A bit off topic here I know but I am thinking about fuel economy. I was driving my 95 Dodge with Fi home tonight. I was climbing hills and mirroring when I thought the vac secondaries when my Ford would kick in. Lol no real reason just jacking around. I am hoping I'll notice some big rush of power but we shall see.
#63
#64
#66
I think it's the other way around - too light a spring will cause the car to bog down as the secondaries open up too quickly and kill the vacuum signal. A heavy spring will just make the car feel down on power overall.
#67
Originally Posted by Holley's FAQ
QUESTION I have a vacuum secondary carburetor that bogs when the secondaries come in. What will cause this?
ANSWER Bogging and hesitation are caused by the secondaries coming in too quickly. You can install a heavier secondary spring and this will prevent the secondary from coming in too soon. If the engine is sluggish in response at full throttle then the secondaries may not be opening soon enough. You will then need to go to a lighter spring. The spring kit is part number 20-13 which will have 7 different springs to fine tune with.
So I guess you could have either a big flat spot on top where you don't have enough venturi or you could have a bog where the secondaries flop open.
#68
I always start with a stiff spring, go too far and then switch back one step when I notice the engine falling on its face. (much easier when you have a quick change cover)
What's a quick change cover? The P/O of my 460 put in one or two steps from the stiffest spring Holley sells. I went down one step and was tired of finagling with all the crap on my CA 460 that I decided to stop.
#69
The 20-59 diaphram cover allows you to change springs by only removing two screws on the top, instead of having to access the three screws on the side behind the choke linkage.
Holley Performance Products Quickchange Vacuum Secondary Housing Cover 20-59
#70
on
I would imagine that being completely mechanical, mechanical fuel injection would only be as good as a carburetor in terms of metering the volume of air being delivered.
That is for the 302 right?
The 300-I6 had different numbers...
Also comparing like for like...
1986 F-150, 2wd, 4 speed manual:OD, Feedback Carb, 23 mpg highway, 20 mpg combined, CO2: 9.3
1987 F-150, 2wd, 4 speed manual:OD, EFI, 20 mpg highway, 17 mpg combined, CO2: 11.0
1986 was last year for Feedback carbs, and 1987 was first year of EFI for the 300-6. And according to the website, the EFI was dirtier with 1.7 more Co2 output than the Feedback carb just a year earlier.
If you keep going forward, the 1988 is even worse.
1988 F-150, 2wd, 5 speed manual (the four speed OD was dropped), EFI, 18 mpg highway, 16 mpg combined, Co2: 11.6
#71
#73
I also wonder what kind of gearing an EFI truck would come with vs a feedback carb. Not enough of the picture is really painted from the site.
Taller gears will produce lower CO2 and better fuel economy, to a point.
LARIAT 85
'80-'86 HOWTO's
28
07-07-2022 03:50 PM
Erndale
12-23-2015 07:03 AM
LARIAT 85
08-11-2011 07:54 PM
3006, carburators, carburetor, carburetors, carburretor, electronic, f150, feedback, ford, fuel, injected, system, trucks, tuning, year
