17in 8 lug rims
Old 01-28-2011, 07:36 PM
BeastF-250's Avatar
BeastF-250
BeastF-250 is offline
17in 8 lug rims
does any one know if ford made a 17in or 16.5in, 8 lug rim for 80-97 trucks? steelie or not?
Old 01-28-2011, 08:47 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
There are steel rims around that are 16.5 inch and will fit those trucks. I can't say for sure if the wheel was actually made for those year trucks though. Never have seen or heard of a 17 inch rim with our bolt pattern though.
P.S. I just did a search on www.car-part.com, and they list a 16.5 inch rim for years 80 thru 82. 83-up they do not show a 16.5 inch rim.
Old 01-28-2011, 08:50 PM
Redneck1465's Avatar
Redneck1465
Redneck1465 is offline
I dont think they made them stock (17s that is) but I know you can get aftermarket rims with that bolt pattern and size.
Old 01-29-2011, 03:20 PM
BeastF-250's Avatar
BeastF-250
well im looking for stock rims just because there cheaper and they would have worked with the tires that im looking to get
Old 12-24-2020, 06:55 PM
gkner's Avatar
gkner
gkner is offline
Rims
Try Auto Rim Shop they seem to have stock or oem rims for fords I've been looking for steel rims for my 2004 F-150 and they seem to have a lot of variety
Old 12-24-2020, 07:06 PM
matt167's Avatar
matt167
matt167 is offline
Keep in mind you cannot use 17" tires on a 16.5" rim or vice verse, regardless of what someone might have told you. The slanted bead of the .5" rim will blow off the 17" tire bead with a good amount of force... I say this because a 17" WILL mount onto a 16.5" rim, BUT it will not seat correctly and it will blow the beads off.
Dodge rims will fit right on, and are 8x6.5 with a large enough hub. Bolt right on. Dodge center caps could also be fit with the correct type lug nut. Factory lugs may work depending.
Old 12-24-2020, 07:54 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Let's hope 9 years later he found a wheel....
Old 12-25-2020, 07:59 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,103 Likes on 1,791 Posts
The other thing to keep in mind with the 16.5" wheel is finding a tire to fit.
I here there are not a lot to pick from so look for a 16" wheels for more tires to pick from.
Dave ----
Old 12-25-2020, 01:33 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,288 Likes on 1,089 Posts
Could kill even.
Old 12-25-2020, 01:44 PM
matt167's Avatar
matt167
matt167 is offline
Originally Posted by tbear853
Could kill even.
Yeah, I wouldn't want to witness it. I've sent an 11L-15 with rim into the ceiling in front of me due to trapped air preventing a bead from seating and pushing it a little to far ( 80 PSI on a nylon tire ). We joke about the dent in the ceiling panel now, but it wasn't funny then.
HVFDFIREFIGHTER1618
02-23-2020 06:55 PM
jaskoskip
01-01-2016 11:08 AM
erikl85
04-27-2003 12:10 AM
Triple Threat
12-12-2002 07:10 PM
Quick Reply: 17in 8 lug rims
