2001 expo running lean bank 1,2
Hi guys,
I am having a problem with my 2001 expedition XLT, with the 5.4L. Im getting the error code that bank one and two are running lean. i have changed/ checked the following:
-Clean MAF...... with MAF cleaner
-Changed fuel filter
-Ran lucus injector cleaner, with premium through the engine
-Changed PCV valve, and elbow
-just checked the whole PCV assmbly all the way to the back of the intake
-Cleaned/ recharged K&N air filter
It war running like **** before i did all this, now its running fine. What other tricks do you guys know?
Thanks for the help
Steve
Thanks for the help
Steve
Hook up a fuel pressure gauge to schrader valve on the fuel rail and take some readings. Most, I say most of the time, when the pump goes it goes. There maybe some intermittent issues that can happen. You may also consider an intake manifold leak. A crack in the manifold or a bad gasket. Check that out also. Look for any broken or cracked vacuum lines too. Anything that would allow extra air to get in that shouldn't. Good luck!
[quote=alloro;9892092]If it's running fine, then what is it that you want to
Well its not running like it should, but before this i had a 93 taurus, and my dad said, if it runns its fine, or run it till it breaks, well i had horrible time in that car, so im trying to fix the problem early so i dont have to fix some huge problem later
steinoles
1997-2006 Expedition & Navigator
02-11-2008 01:23 PM
ezacarias
06-25-2004 09:27 PM
