Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-09-2003, 05:25 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
EEC components and what they do
The electronic engine controls consist of the:
-powertrain control module (PCM) (12A650).
-throttle position sensor (TP sensor) (9B989).
-idle air control valve (IAC valve) (9F715).
-engine coolant temperature sensor (ECT sensor) (12A648).
-camshaft position sensor (CMP sensor) (6B288)
-4.2L vehicles — camshaft synchronizer.
-4.6L, 5.4L vehicles — camshaft position sensor.
-crankshaft position sensor (CKP sensor) (6C315).
-mass air flow sensor (MAF sensor) (12B579).
-intake air temperature sensor (IAT sensor) (12A697).
-heated oxygen sensor (HO2S) (9F472).
-knock sensor (KS) (12A699) (4.6L, 5.4L).
-vehicle speed sensor (VSS) (9E731).
-cylinder head temperature (CHT) sensor (6G004).
The powertrain control module needs the following inputs to calibrate the engine properly:
-camshaft position.
-engine rpm.
-engine coolant temperature.
-amount of engine detonation.
The throttle position sensor :
-sends the powertrain control module a signal indicating the throttle plate angle.
-is the main input to the powertrain control module from the driver.
The idle air control valve 4.6L, 5.4L:
-controls bypass air around the throttle plate at low speeds.
-is controlled by the powertrain control module.
The engine coolant temperature sensor :
-sends the powertrain control module a signal indicating engine temperature.
-resistance decreases as coolant temperature increases.
The camshaft position sensor :
-sends the powertrain control module a signal indicating camshaft position used for fuel synchronization.
The crankshaft position sensor :
-sends the powertrain control module a signal indicating crankshaft position.
-is essential for calculating spark timing.
The mass air flow sensor :
-sends the powertrain control module a signal indicating mass airflow rate of air entering the engine.
The intake air temperature sensor :
-sends the powertrain control module a signal indicating the temperature of the air entering the engine.
-resistance decreases as temperature increases.
The heated oxygen sensor :
-has the ability to create a voltage signal dependent on exhaust oxygen content.
-provides feedback information to the powertrain control module used to calculate fuel delivery.
The 4.6L knock sensor is located in the lifter valley. The 4.2L knock sensor is located on the RH side of the block. The 5.4L has a unique linear knock sensor located in the lifter valley.
-sends a signal to the powertrain control module indicating engine detonation.
-if detonation is occurring, the powertrain control module then changes engine timing.
The cylinder head temperature (CHT) sensor 4.6L, 5.4L:
-is mounted into the wall of the cylinder head and is not connected to any coolant passages.
-sends a signal to the powertrain control module indicating the cylinder head temperature.
i-f the temperature exceeds 126°C (-258°F) 5.4L, 130°C (265°F) 4.6L, the powertrain control module disables four fuel injectors at a time. The powertrain control module will alternate which four injectors are disabled every 32 engine cycles. The four cylinders that are not being fuel injected act as air pumps to aid in cooling the engine.
-if the temperature exceeds 154 °C (310°F) 5.4L, 166°C (330°F) 4.6L, the powertrain control module disables all of the fuel injectors until the engine temperature drops below 153°C (308°F) 4.6L, 154°C (310°F) 5.4L.
DTCs are set.
-If the engine reaches critical temperature, the following happens:
The coolant temperature gauge pointer will read fully hot at 121°C (250°F).
The check gauge warning indicator will illuminate.
The vehicle speed sensor :
-is gear driven by the transmission.
-sends a signal to the powertrain control module indicating vehicle speed.
The clutch pedal position (CPP) switch:
-sends a signal to the powertrain control module indicating clutch pedal position.
The fuel pressure sensor:
-is mounted on the fuel injection supply manifold (9F792) downstream of the fuel injector.
-regulates the fuel pressure supplied to the fuel injectors.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #2 (permalink)
Old 03-12-2003, 11:56 PM
damonlan damonlan is offline
damonlan is starting off with a positive reputation.
How about what the varrious abbreviations mean when the odometer is in the test mode? Can't figure some of them out.
__________________
Damon
KC5AOS
  #3 (permalink)
Old 03-13-2003, 12:10 AM
Racerguy's Avatar
Ok let's try this.......
Where it says HEC that means Hybrid Electronic Cluster.
Odometer Display Description
GAGE - Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
All segments illuminated - Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
bulb - Illuminates all micro-controlled lamps and LEDs (low oil pressure/high coolant temperature, low fuel, service engine soon, brake, low range). INSTALL a new bulb or LED as necessary.
r - Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). If alternating flashes of FAIL and ROM level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster .
EE - Displays hexadecimal value for EE level (used when requesting assistance from the hotline). If alternating flashes of FAIL and EE level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster .
dt - Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from the hotline).
dtc - Displays continuous DTCs. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step.
enG - Displays the English speed in mph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0.
m - Displays the English speed data (mph) received from the PCM via the SCP network. Displays the metric speed in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0.
tAc - Displays the tachometer data received from the PCM via the SCP network. Tachometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if engine rpm is 0.
FUEL - Displays the actual A/D fuel level. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. If the value displayed is between 0 and 20, the circuit is shorted. GO to Pinpoint Test D .
255=open send +/-0
232=Full stop +/-10
215=Full mark +/-10
178=3/4 mark +/-8
138=1/2 mark +/-7
93=1/4 mark +/-5
41=E mark +/-4
54="LOW FUEL" (0-59)
0-18=short (0-20 max.)
OIL - Displays the code (0-255) for the oil pressure switch input to the HEC. Displays the oil pressure reading input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6 psi) will display a value between 000 and 176. A low oil pressure (less than 6 psi) or an inoperative engine oil pressure switch will display a value greater than 176.
dEGC - Display of engine temperature in Degrees C input from cylinder head temperature sensor. If the value displayed is -40C, the SCP message for engine temperature has not been received for more than 5 seconds. GO to Pinpoint Test E .
49 C="C" mark.
60 C=Normal band start.
120 C=Normal band end.
119 C=Temperature warning indicator ON.
"-40" C=No SCP Message for 5 sec.
br - Displays the brake fluid level input to the HEC.
bAtt - Displays the code (0-255) battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
93-102=6.9-9.1 volts (Low voltage)
115-124=8.5-10.7 volts (Norm band start)
215-225=15.8-18 volts (Norm band end)
230-241=16.9-19.1 volts (High voltage)
rhEo - Displays the present hexadecimal value for the instrument cluster backlighting pulse width modulated (PWM) input to the HEC (used when requesting assistance from the hotline).
rhi - PWM input duty cycle.
rhS - SCP hexadecimal dimming step (used when requesting assistance from the hotline).
rho - Output driver counts in hexadecimal format (used when requesting assistance from the hotline).
Cr - Displays the present RUN/START sense input. Display will show -L with the ignition switch in the START position and -h with the ignition switch in the RUN position.
ALtF - Displays 8-bit hexadecimal value for alternate fuel level. Display will show a value between OO and FF if the message is received.
PA-PE7 Not used.
GAGE Repeats test display cycle.
__________________
Forum Guidelines
this space for rent
  #4 (permalink)
Old 07-13-2003, 11:04 PM
dbeames's Avatar
dbeames dbeames is offline
dbeames is starting off with a positive reputation.
Excellent. Just for now, here is the link to the thread that I did the VIN breakdown, as much of it as I know.
http://www.ford-trucks.com/forums/sh...hreadid=130719
__________________
D Beames
98 F150 4.2L 3.55 Auto K&N Filter
  #5 (permalink)
Old 05-31-2004, 08:00 AM
smoken79 smoken79 is offline
smoken79 is starting off with a positive reputation.
[b]i Have A 1997 Explorer P140 Code Does This Code Mean My Back Oxygen Sensor Needs Replaced Or My Front Setting In The Seat The Right Bank Would Be The Passenger Side Downstream Would Be The Second Sensor Back From Eng To Muffler Is The Correct Way Of Looking At This And The Right Sensor To Change Any Help Or Were To Go To Find Out How To Fix The Problem Aftering Getting Code Would Be Greatly Appreciated Thanks Smoken79
  #6 (permalink)
Old 05-31-2004, 09:09 AM
Racerguy's Avatar
Hi smoken and welcome to FTE
A P140 isn't a good code number. The code should have one more digit....P****.
If you can get it scanned again and let us know what the number is we can probably help.
__________________
Forum Guidelines
this space for rent
  #7 (permalink)
Old 02-02-2006, 08:54 PM
bronocIInoob bronocIInoob is offline
bronocIInoob is starting off with a positive reputation.
you say the idle control valve is only on the 4.6 and and 5.7, it is also on the 2.9 sence my bronco too has it as well
  #8 (permalink)
Old 02-04-2006, 11:23 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Quote:
Hey , noob...bringing back a two year old post.....why?
The posted data was a cut and paste from the PC/ED for a 97-03 F150.
All fuel injected Fords have an IAC.
Steve
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #9 (permalink)
Old 02-04-2006, 05:53 PM
its goes without saying, i was bored..lol And i had no notifycation this was a strictly 97-03 f150 posting. Its a good thing i didnt do anything with my bronco that i saw here or else i coulda screwed somthing up.
  #10 (permalink)
Old 02-04-2006, 05:56 PM
also not to sound like a have an additude or anything. But its somones choice to repost to what i have posted here, i normally dont look at the date of the post anyway. I was just giving advice, wasnt I?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
