Rear Axle Problem?
Rear Axle Problem?
About a week ago I began to notice a slight jerk when backing out of the garage. Trans shifted into reverse ok, jerk happened after backing out about 3 feet. Then yesterday I was about 20 feet out and it jerked so hard I thought I had hit something. No problem going forward and after driving 7 miles and the truck was warmed up it wouldn't do the jerk when backing up. I have 3.73 ratio dif.
Any ideas, I hope it could be simple as a fluid change, 140k on truck and I don't remember ever changing the fluid.
Thanks, Walt
Thanks, Walt
It would not cost alot to pull the cover and drain the oil.Inspect the gears and all.Fill it up with fresh oil and the friction modifier and try it.
Welcome to guzzle's Rear Differential Maintenance Web Page
http://www.guzzle7pt3.com/fdiff.php
Not a Rear Axle Problem
Thanks for the advice robs01f250 and riverrat41, thought I should get back to you on the real problem.
Both L/S & R/S rear brake pads had broke free of the plates they were bonded to. They were the high dime NAPA Ceramic pads, I only had 25,000 miles on them but they were installed 4 years ago so NAPA would'nt give me a break (two year warranty).
No more NAPA CRAPA for me.
naps1saps
09-12-2012 01:16 PM
