Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 01-28-2011, 01:06 AM
jeffsonday's Avatar
jeffsonday jeffsonday is offline
Garage is empty, add now
jeffsonday is starting off with a positive reputation.
long crank time before starting
My truck cranks over for a long time before starting. It doesnt seem to matter what the temp is. Summer or winter it cranks for a quite a while before it starts. It does always start and seems to run fine after starting. It does start when its really cold to. Just needs to crank to long from other trucks I have seen. Any ideas?????
  #2 (permalink)
Old 01-28-2011, 01:44 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 is gaining momentum as a positive member of FTE.Fullcrew7.3 is gaining momentum as a positive member of FTE.
Short out the Glow plug relay and see if that makes the difference. It's on the left side of the fuel bowl under the engine cover. They are prone to failure. If that's the case, GPR109 from NAPA or the better Stancor relay (someone help me out with the number). If that doesn't help, then maybe your glow plugs need replacing or the under vavle cover harness could be loose or burnt. Try the GPR ( glow plug relay) first. That's likely the problem.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW, DIY 4x4 conversion, 4.10 gears, Sky 3" RSK, DIY 4" exhaust, 3" diamond eye DP, SC 1705, Stage 1 Rosewood sticks, Valair SMF, SD I/C, 37/12.50/16.5 wranglers and some more DIY stuff
Tags
2005, 73, awhile, crank, cranking, cranks, diesel, excessing, f150, ford, long, powerstroke, start, starting, starts, time, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
