6.7 Liter PowerStroke
Old 01-27-2011, 10:29 PM
BroncoDually's Avatar
BroncoDually
BroncoDually is offline
I've got a question on the 6.7 Liter PowerStroke:How hard is to Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. DOHC gas powered V8 engine
Old 01-27-2011, 11:49 PM
djjoshuad's Avatar
djjoshuad
djjoshuad is offline
um... what? Either you are very confused, or a mod needs to delete this thread. maybe both :-S
Old 01-28-2011, 02:10 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
I just wanna know what happens when you compress gasoline to 18,000 psi and inject into a cylinder with a compression ratio of what?, 13:1?
Old 01-28-2011, 02:13 AM
djjoshuad's Avatar
djjoshuad
bad things, man. bad things.
Old 01-28-2011, 07:20 AM
Tom's Avatar
Tom
Tom is offline
Originally Posted by BroncoDually
I've got a question on the 6.7 Liter PowerStroke:hard is to Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. DOHC gas powered V8 engine
Now I'm confused.
The 6.7L PSD is an OHV engine, and has nothing to do with the ancient 427.
It won't run! Gasoline is rated in terms of octane, which is by definition the resistance to knock. Fundamentally a diesel engine's combustion cycle is almost identical, but this is the normal way it runs instead of a dangerous event. Cetane is the exact opposite of octane, as it refers to how quickly it will light.
This is why when you read of stories of guys filling their diesel pickups with gas the truck stumbles and dies rather than taking off.
Old 01-28-2011, 08:35 AM
Big Ruth's Avatar
Big Ruth
Big Ruth is offline
I dont even know how the people that are replying can even make sense of what the sentence is even asking.
Is this a riddle?
Old 01-28-2011, 08:50 AM
rickatic's Avatar
rickatic
rickatic is offline
...never mind
Old 01-28-2011, 10:22 AM
Big Ruth's Avatar
Big Ruth
Big Ruth is offline
Ahh. Ok Bore and stroke the 6.7 to 427 cubic inches. I dont think 20 cubic inches will gain you much.
I dont know what a honing machine would do to the CGI block.
Old 01-28-2011, 11:33 AM
djjoshuad's Avatar
djjoshuad
he also wants to make it a DOHC gas powered V8. LOL
Old 01-28-2011, 04:03 PM
rickatic's Avatar
rickatic
rickatic is offline
...never mind
Old 01-29-2011, 07:50 PM
BroncoDually
Wink 6.7 Liter PowerStroke
My Plan is Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. and convert the 6.7 Liter (406 cu. in.) PowerStroke to gasoline use for the DOHC 427 engine
Old 01-29-2011, 07:58 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Post lots of pictures
Old 01-29-2011, 08:11 PM
rickatic's Avatar
rickatic
rickatic is offline
why.........
Old 01-29-2011, 08:37 PM
Tom's Avatar
Tom
Tom is offline
It simply can't work like that for a number of reasons.
1. The Powerstroke is an OHV engine
2. Would need different crank and pistons. These things aren't available now and never will be.
3. This thing is HEAVY. Nearly 1,000 lbs for the engine alone; you do NOT want this in anything not built properly for the weight of a diesel.
4. And the list can go on...
I'm normally not one to say that something can't ever happen, but in this case it can't be done. This is really far outside the realm of possibility...
Old 01-29-2011, 11:00 PM
tbaker00's Avatar
tbaker00
tbaker00 is offline
Why would you want to convert a diesel to a gas? What a waste of a marvelous engine!
Quick Reply: 6.7 Liter PowerStroke
