6.7 Liter PowerStroke - Ford Truck Enthusiasts Forums
Old 01-27-2011, 11:29 PM
BroncoDually's Avatar
BroncoDually BroncoDually is offline
BroncoDually is starting off with a positive reputation.
I've got a question on the 6.7 Liter PowerStroke:How hard is to Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. DOHC gas powered V8 engine
Old 01-28-2011, 12:49 AM
djjoshuad djjoshuad is offline
djjoshuad is gaining momentum as a positive member of FTE.djjoshuad is gaining momentum as a positive member of FTE.
um... what? Either you are very confused, or a mod needs to delete this thread. maybe both :-S
Old 01-28-2011, 03:10 AM
ruschejj's Avatar
ruschejj ruschejj is online now
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I just wanna know what happens when you compress gasoline to 18,000 psi and inject into a cylinder with a compression ratio of what?, 13:1?
Old 01-28-2011, 03:13 AM
bad things, man. bad things.
Old 01-28-2011, 08:20 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Originally Posted by BroncoDually View Post
I've got a question on the 6.7 Liter PowerStroke:hard is to Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. DOHC gas powered V8 engine
Now I'm confused.
The 6.7L PSD is an OHV engine, and has nothing to do with the ancient 427.
Quote:
It won't run! Gasoline is rated in terms of octane, which is by definition the resistance to knock. Fundamentally a diesel engine's combustion cycle is almost identical, but this is the normal way it runs instead of a dangerous event. Cetane is the exact opposite of octane, as it refers to how quickly it will light.
This is why when you read of stories of guys filling their diesel pickups with gas the truck stumbles and dies rather than taking off.
Old 01-28-2011, 09:35 AM
Big Ruth Big Ruth is offline
Big Ruth is starting off with a positive reputation.
I dont even know how the people that are replying can even make sense of what the sentence is even asking.
Is this a riddle?
Old 01-28-2011, 09:50 AM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
...never mind
Old 01-28-2011, 11:22 AM
Ahh. Ok Bore and stroke the 6.7 to 427 cubic inches. I dont think 20 cubic inches will gain you much.
I dont know what a honing machine would do to the CGI block.
Old 01-28-2011, 12:33 PM
he also wants to make it a DOHC gas powered V8. LOL
Old 01-28-2011, 05:03 PM
...never mind
Old 01-29-2011, 08:50 PM
Wink 6.7 Liter PowerStroke
My Plan is Bore & Stroke the 6.7 Liter (406 cu. in.) PowerStroke to 427 cu. in. and convert the 6.7 Liter (406 cu. in.) PowerStroke to gasoline use for the DOHC 427 engine
Old 01-29-2011, 08:58 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Post lots of pictures
Old 01-29-2011, 09:11 PM
why.........
Old 01-29-2011, 09:37 PM
Tom's Avatar
It simply can't work like that for a number of reasons.
1. The Powerstroke is an OHV engine
2. Would need different crank and pistons. These things aren't available now and never will be.
3. This thing is HEAVY. Nearly 1,000 lbs for the engine alone; you do NOT want this in anything not built properly for the weight of a diesel.
4. And the list can go on...
I'm normally not one to say that something can't ever happen, but in this case it can't be done. This is really far outside the realm of possibility...
Old 01-30-2011, 12:00 AM
tbaker00's Avatar
tbaker00 tbaker00 is offline
tbaker00 is starting off with a positive reputation.
Why would you want to convert a diesel to a gas? What a waste of a marvelous engine!
Torque Pro Ford 6.7L Extended PIDs MPD56 6.7L Power Stroke Diesel 971 02-21-2017 06:27 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
Parts-'53-'56 F100, T-Bird, Mustang, Cobra Jet, Mtrs., 9"ers, few Chrylser/Dodge 1's... '50'sFever Ford Truck Parts for Sale 4 09-27-2014 06:25 AM
300 cu"in" carb portagoosey 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-16-2014 11:54 AM
2011 6.7L Powerstroke and ScanGauge II XGAUGE codes swengle 6.7L Power Stroke Diesel 2 03-05-2013 06:47 PM
Tags
427, 67, 67liter, big, cubic, djjoshuad, f150, ford, forum, forums, gas, inches, liter, moderator, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
