02 4.6 coil packs?
Old 01-27-2011, 10:11 PM
F250army45d's Avatar
F250army45d
F250army45d is offline
02 4.6 coil packs?
Accel 140032-8 Accel Super Coil Any one use these yet if so what thoughts yay nay? I have an 02 F150 4.6 did plugs pcv air filter fuel filter and it still seems to have a shutter at idle next thought was new coils truck was bought used for work and now has 120000 plus miles, I have put in three months about 8 or 9000.
Old 01-28-2011, 01:08 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Do not use any coils but factory originals.
The ACCELs' are made in PRC and will fail and may cause more issues that you want to have over time.
There is a horror story behind the 8 I tried and lost them all one at a time over a year's time and cost a big bundle to learn just how bad they can be.
There is no one to stand behind them, with the warrenty of only 30 days that is offered from the vendors.
I know they have a large number of complaints but still sell them.
A coil that is faulty usually does not only cause an issue at idle but at other times as well.
A 'specific issue' with coils is a studder or missfire at cruise with light throttle over 45 mph.
It usually is one coil with shorted turns that has low output but not a hard failure and does not set a code or CEL.
Good luck..
Old 01-28-2011, 10:29 PM
F250army45d
Thanks I bought them and installed them mostly because the price, each was like seven dollars cheaper then the oem offered ones so were see how it goes.
Old 01-29-2011, 01:26 AM
phil6608's Avatar
phil6608
phil6608 is offline
So you saved 56 bucks?
Good luck,,,,,,,,,,live and learn!
Old 01-30-2011, 12:37 PM
F250army45d
So wheres a good place to get some new coils at a decent price? been looking at htese any one runing these? Advance Auto Parts: Ignition Coil by BWD - Part E262Z
Ignition Coil | 2002 Ford F150 1/2 ton P/U 4WD 8 Cylinders W 4.6L EFI | AutoZone.com
Old 01-30-2011, 12:54 PM
phil6608's Avatar
phil6608
phil6608 is offline
I thought you already bought the accels?
You can get Motorcraft for the same price as you fist link and the advance auto part ones are cheaply made.
Rockauto has Motorcraft for 45.99
And this place has Motorcraft for 43.99 I think.
(DG-508)Motorcraft DG508 Gasoline Ignition Coil-DG508. - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old 01-30-2011, 01:20 PM
F250army45d
phill6608 thanks for the link I had looked and most others were over fourty up in the sixty range, I did buy the accels they seem to help the stutter but I think my trucks eatin more gas.
Chad T. Keogh
1997 - 2003 F150
07-18-2017 02:24 PM
simptek
1997 - 2003 F150
23
05-02-2017 03:25 PM
db_tanker
2004 - 2008 F150
03-17-2017 03:22 PM
ugh3012
1999 to 2016 Super Duty
05-24-2016 09:53 PM
calazo
01-07-2009 10:40 PM
Quick Reply: 02 4.6 coil packs?
