Rusty hitch....how bad before I should replace?
Old 03-15-2015, 02:20 PM
fordboy67's Avatar
fordboy67
fordboy67 is offline
So, I just crawled under the X to scrape all the rust off the hitch to do the annual spring repaint. While scraping the loose rust a hole developed on the bottom tube about three inches long by about a quarter inch wide. I thoroughly inspected rest of hitch and all seems solid. I really hate rust! I know it will do nothing but get worse, but my question is, should I replace the entire hitch, or do I still have a couple more years left in it? If they were easier to find and not as expensive, I would just replace it, but I had a hard time finding a replacement two years ago! Thanks in advance for your opinions!
Old 03-15-2015, 02:23 PM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
Nope. It is now junk, unless your only going to put a bike rack in it. Mine doesn't have a hole in it, but it is rusty. I bought a Curt hitch for the X, they now make hitches for them.
Get it replaced if you will be towing!
Old 03-15-2015, 02:31 PM
fordboy67's Avatar
fordboy67
That's what I was thinking, too. Where did you get your Curt hitch?
Old 03-15-2015, 02:32 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Trash it. Well scrap it for a few bucks actually
Old 03-15-2015, 04:28 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Replace it with the Curt. I just did mine. Two beans and change on Amazon. It was a lot of work, but the right thing to do.
Old 03-15-2015, 04:34 PM
mecdac's Avatar
mecdac
mecdac is offline
Please replace ASAP.
If you are towing in the Peach State let me know your itinerary, so I can stay home.
Old 03-15-2015, 04:40 PM
1 Excursion camper
I picked mine up from auto anything. $139 with a code and free shipping.
I'll be putting mine in, in a couple weeks. I'll be cleaning up and repainting the skid plate along with the frame rails.
Old 03-15-2015, 07:34 PM
fordboy67's Avatar
fordboy67
Don't worry, won't be towing until I replace it! Not that it matters down there, last March when I drove through Atlanta on the way to Mickeyworld, I couldn't believe the drivers! You either go 85 or 40....nothing in between!
Old 03-15-2015, 07:39 PM
fordboy67's Avatar
fordboy67
Just checked autoanything.com (thanks tor the tip) and quote was $232. You got a screamin deal! Going to check local Radco to see if thay may have one in stock, but probably going through autoanything.
Old 03-15-2015, 07:48 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Do a google search for a coupon or check any of the diesel magazines..might can get it cheaper.
Old 03-15-2015, 08:02 PM
fordboy67's Avatar
fordboy67
Thanks for the tip, Monty! I'll check it out!
Old 03-16-2015, 06:47 AM
1 Excursion camper
Ya, it was a Christmas time deal. couldn`t pass it up!
Old 03-16-2015, 07:24 AM
mecdac's Avatar
mecdac
mecdac is offline
Yes, I'm the one doing 80.
Old 03-16-2015, 09:01 AM
kc8vey's Avatar
kc8vey
kc8vey is offline
Use current coupon code lucky20 for 20% off so its 185.59 shipped
Old 03-16-2015, 12:02 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Chuck, what do you normally tow?
Brent may have a repair for this.
Quick Reply: Rusty hitch....how bad before I should replace?
