HOWTO - DSII Conversion (swap from TFI or EECIII / EECIV to DSII) - Ford Truck Enthusiasts Forums
Old 01-27-2011, 09:58 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Threads detailing how to revert a computer-controlled engine to a DuraSpark II
configuration.
Begin outermost table definition
<table style="background-color: rgb(218, 222, 235); text-align: left; width: 810px;" border="1" cellpadding="5" cellspacing="0"><tbody><tr><td style="vertical-align: top;">
End outermost table definition
Duraspark II Conversion - How To
Quote:
Originally Posted by dyingtolive View Post
Two days ago, I converted my '84 F150, With a 300 I6, 4 Speed Transmission, and Four Wheel Drive over to the Duraspark II ignition system. Here's how I did it:
First things first. Why convert to the older Duraspark II (DSII) ignition system?
Simple. the DSII system is a much more simple and reliable system than the ignition system found on F-Series trucks made from '84-'86. It doesn't require tons of wires, a computer, or that terrible electronic feedback carburetor that never seems to work right. The system also features an automatic spark retard while cranking to reduce the load applied to the starter motor.
What you'll need:
To convert your truck to the DSII system, you'll need a few parts.
1. Distributor
Begin close of outermost table
</td></tr></tbody></table>
End close of outermost table
Duraspark II Wiring Harness..??
So, I've pretty much gotten everything prepped and ready for the Duraspark II conversion. However, I was looking over my wiring harness, and thought that I had it all figured out, until I noticed one wire with a single plug on it. I've looked in previous threads/write ups, and I haven't been able to figure it out. Any ideas?
Duraspark II conversion for 86 I-6
Quote:
Originally Posted by Superred2 View Post
I'm just trying to make sure I have all of my ducks in a row before I attempt to do this Duraspark conversion. I have an 86 F-150 I-6, 4 speed, 4x4 and someone has installed a manual choke to the current setup and it runs like crap at idle.
I have the control module and the wiring harness off of a 78 F-150 and I was just going to buy a rebuilt distributor for a 78 year truck ($50) and a coil ($22) for the same.
First of all, what else do I need? I have read that I need to get a carb off an older truck as well. The parts guy at O'Reilly's asked if the distributor was a one or two vacuum line setup. I'm not sure if I get a carb off of an older truck if that would make a difference.
I need a drink...
Old 05-20-2015, 05:00 PM
Tarheel Blue's Avatar
Tarheel Blue Tarheel Blue is offline
Tarheel Blue is starting off with a positive reputation.
Can't see images?
All I get is "image shack" logo. What's up? Would really help me to see pix
Old 05-21-2015, 09:18 AM
ctubutis's Avatar
The guy who wrote the posts apparently deleted the images from the hosting service, so they're no longer available. Guess I should remove those post entries from this howto someday....
FAQ - 5-speed transmission swaps ctubutis '80-'86 FAQs (Frequently Asked Questions) 2 01-20-2016 12:26 AM
FAQ - Exploded View Diagrams (off site) ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 08:00 PM
FAQ - How to determine if engine is a 302 or 351W ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 02-21-2011 01:20 PM
HOWTO - Adjusting Hydraulic Valves ctubutis '80-'86 HOWTO's 0 02-10-2011 09:58 PM
FAQ - EEC IV Diagnostic Codes ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 01-30-2011 06:35 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
dsii conversion
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
