Drag up tank? (pics welcome) - Ford Truck Enthusiasts Forums
Old 01-27-2011, 09:18 PM
bulla's Avatar
bulla bulla is offline
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
I'm thinking of building my own drag up tank but I'm looking for something different. Anyone have any ideas? Even if you have pics of your own tank post em. And finally what are you thoughts of a drag up tank, messy, extra weight, problems with dot. Is it worth it? I always wanted one for filling my tractor or for road trips. Let me know what you think.
Old 01-28-2011, 07:36 AM
bulla's Avatar
Bump! Anyone have anything for me?
Old 01-28-2011, 08:13 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Quote:
I have a 5 gal, and two 2 gal diesel cans in the bed of my truck. I can send you a pic if you like.......lol
Old 01-28-2011, 08:17 AM
bulla's Avatar
Not exactley the look I was going for!
Old 01-28-2011, 08:21 AM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
I have a RDS aux. tank/toolbox combo in my truck. Works great. Gravity fed to my factory fill line. If you build one be sure you baffle it or it will slosh like crazy.
Old 01-28-2011, 08:39 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
X2 on the baffles. My VO tank is 200 gals and only baffled side-to-side. At 1/2 tank, it rocks pretty good if i stop fast.
I think a tank/toolbox combo is great. Incorporate the pump/filter/hose into the toolbox for a cleeeean look. Gravity feed to stock tank would be nice, but pump ain't so bad.
Make sure tank stays in bed in the event you have to drive over a Kia. Strong tabs/brackets are a good idea. Also recommend a coating for steel tank interior - Red Kote is good stuff...
I think 'legal' max is 110gals for DOT...
Old 01-28-2011, 08:48 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Not sure what a drag up tank is, but here is what I have. Like you don't know already. lol
Old 01-28-2011, 09:19 AM
Quote:
They call it a 'drag up' tank cause when ya quit (aka. drag up) you always make sure that tank is full... (of 'their' fuel!)
Old 01-28-2011, 09:26 AM
Ziggy.'s Avatar
Ziggy. Ziggy. is offline
Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.
I have a 44gal tank out of an excursion mounted where my spare tire use to be. Gives me a total of 73 gal and a practical range of about 1000-1200 mi running empty down the highway and back and forth to work.
Old 01-28-2011, 09:31 AM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Quote:
I was just going to let Bulla know about that mod Cory, its a good one and I still didn't do it to mine, lol. Rick's tank is the shizzle also..
Old 01-28-2011, 09:37 AM
Ziggy.'s Avatar
Quote:
Lol you'll get around to it pop. I like the capacity of the ex tank, its as big as you can possibly go in that location, and the ex tank has the 1/4'' thick gaurd around bottom and sides, which I have used quite a bit lol.
Bulla you can also use some of the tanks like out of some broncos and other vehicles as well, I've heard of some going that route.
Old 01-28-2011, 09:39 AM
Quote:
Darn, If I drag up, I will be have to take the diesel from me.
Old 01-28-2011, 09:55 AM
qbenplaya00's Avatar
qbenplaya00 qbenplaya00 is offline
qbenplaya00 has a good reputation on FTE.qbenplaya00 has a good reputation on FTE.
just my 2cents... why dont you get a Fuel Cell? its like having 2 gas tanks.
Old 01-28-2011, 10:02 AM
bulla's Avatar
Rick did you go take that pic this morning just for me? I'm big sure why they call it that or at least that's what I've heard it called. Aux. Tank would be acceptable I guess.
Old 01-28-2011, 11:55 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I have a Transfer Flow 98 gallon tank that transfers fuel to the 38 gallon main tank on an as needed basis.
38 gallon fuel tank (& external fuel pump?) Brain's 97 Diesel 1987 - 1996 F150 & Larger F-Series Trucks 2 11-04-2016 07:27 PM
Drag Link and Tie Rod Torque Specs leardvr 1968-2013 Full Size Vans 2 10-10-2015 03:47 PM
Drag Link The Freak WTB - Parts & other 3 04-30-2011 03:24 PM
Drag truck? purgeofdarkness 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-23-2010 06:53 AM
Loose steering.. replace pitman arm with drag link? Kickinbass23 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-05-2010 03:47 PM
Tags
97, aux, bradenton, building, deisel, diesel, drag, dragup, draguptank, f250, formal, fuel, tank, tanks, turcks, wwwdiesel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
