4WD shift linkage. - Ford Truck Enthusiasts Forums
4WD shift linkage.
Old 01-27-2011, 06:38 PM
87F250Lariat 87F250Lariat is offline
87F250Lariat is starting off with a positive reputation.
4WD shift linkage.
Last year when my front drive shaft went out, it bent and broke my 4WD shift linkage.
The truck is an 87 F250 4WD C6 6.9L diesel. I can't seem to find the shift linkage for sale anywhere. Junkyards, ebay, craigslist, aftermarket stores.
Does anybody know where I may be able to purchase this, or have one for sale, or know another term for it I could use to search it.
Old 01-27-2011, 06:50 PM
aguitarestv aguitarestv is offline
aguitarestv is starting off with a positive reputation.
i know the stealership has them for mucho dinero. theres was a thread i scene not to long ago with aftermarket ones, do a search, and you will find it.
Old 01-27-2011, 06:53 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Yes. Use the search function. has been asked about 8 times this month
Old 01-27-2011, 07:00 PM
I am searching as I posted this, have yet to come across it though.
Old 01-27-2011, 07:08 PM
Quote:
You must not be trying to hard
Let me google that for you
And here i used your EXACT thread title in the search section "4wd shift linkage"
Ford Truck Enthusiasts Forums - Search Results
Old 01-27-2011, 07:10 PM
Very good, and I did the same. I have been going through these threads and have yet to find anybody linking to a site to purchase one.
Lots of threads on how to lube them, but mine is far past that.
Old 01-27-2011, 07:23 PM
last post in the thread
http://www.ford-trucks.com/forums/10...ter-stuck.html
Old 01-27-2011, 07:32 PM
Hmm. Not sure what catagory he searched under on Rock auto to find it. Also, I don't know what that fancy looking thing in your pictures is, but if that is what he was talking about I don't think that is what I need.
I need the entire linkage from the shifter down to the transfer case. Now that I think about it, my 4wd shifter isn't mounted to anything, I can just pull it up inside the truck. Is it supposed to have some sort of solid pivot mount? If so, I may be in more trouble than I first thought even.
I just hate laying in the snow under the truck to put it in 4WD.
I'll search around again tomorrow after work.
Old 01-27-2011, 07:44 PM
If your truck doesnot have that cast aluminum braket, you have the full steel setup and i have no clue how you F*%# that up
Old 01-27-2011, 07:46 PM
Well....
I'm assuming it happened at the same time as this:
Old 01-27-2011, 09:10 PM
that looks like one chunkafied trans!
Old 01-27-2011, 09:14 PM
emkay4597 emkay4597 is offline
emkay4597 is starting off with a positive reputation.
That looks like a job for some JB Weld...
Old 01-27-2011, 09:17 PM
and duct tape. i see a trip to the junk yard in your future.
Old 01-27-2011, 09:21 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
I've seen drive shafts do some damage after breaking loose but this one takes the prize.
I think a bungee cord is more appropriate in this case.
If I would have only known, but I gave a linkage away like the one you needed to someone who bought my old M5OD and he probably won't need it.
Old 01-28-2011, 03:21 AM
Aww )=
Lol, I replaced the transmission and tcase (There was a huge hole in the tcase) and repaired the wiring and body damage. Just woke up to find snow on the ground outside. Hope I don't need my 4WD this morning.
How to shift into 4wd manually linkage broken bettyford93 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-02-2014 07:54 AM
transfer case shift linkage ShortBed'86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-06-2012 11:46 AM
Trans shift linkage loose bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 3 05-21-2011 12:26 AM
1977 F250 Transfer case question Nick_F150 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-22-2008 04:53 PM
???????E4OD --- C-6 Swap ??????? showcow Clutch, Transmission, Differential, Axle & Transfer Case 13 02-27-2006 09:32 PM
Tags
1983, 1996, 2007, 2010, 4wd, drive, f150, f250, f350, ford, forum, linkage, shift, shifting, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
