Cooling fan on too much? ***Fixed*** - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 01-27-2011, 04:28 PM
vamstad vamstad is offline
vamstad is starting off with a positive reputation.
2002 Escape w/ 3.0 v6; 90,000 miles
The electric cooling fan on my escape seems to come on and run more than it should. In cool weather the fan comes on once it is at operating temps (read from interior gauge) and will not shut off unless I turn the heat and interior fan on full (air seems rather hot...gauge is right in the middle between hot and cold at operating temp). I also feel that the fan is running when I am going down the highway at 55mph (hard to tell with road noise but, as soon as I slow down to where I can hear the engine, it is on. Is this normal? No codes are being thrown by the ECU so, no check engine light.
When the other cars on my street pull into their driveway, I hardly ever hear their cooling fans. If my wife pulls up, the low speed one is always on and sometimes kicks up to the high speed fan after a momment or two running at idle.
Any thoughts?
Oh yeah, just replaced the water pump and flushed the system...didn't have any effect on the fan issue.
Old 04-19-2011, 05:31 PM
Fixed! It turns out that a $20.00 Coolant Temperature Sender (that requires no tools to install in my 3.0 v6) from RockAuto solved the problem.
P0480 Cooling fan control circuit malfunciton SilentWeld 1999 to 2016 Super Duty 0 09-22-2016 11:03 AM
Is it ok for my trans to run cool? fixit5561 1997-2006 Expedition & Navigator 6 06-28-2016 03:11 PM
2010 F150 Cooling fan on too often Ken Scriven 2009 - 2014 F150 5 06-08-2015 08:08 AM
2006 6.0 Fan Clutch??? Utah Jake 6.0L Power Stroke Diesel 9 06-07-2015 12:47 PM
Thoughts and observations on Lincoln Mark VIII fan conversion (kinda long) Bullitt390 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-09-2009 08:41 PM
Tags
2006, 30, constantly, cooling, edge, escape, fan, fans, ford, noise, normal, operation, run, temp, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
