1981 4.9 Liter Straight-6 Oil leak
Well I picked up an awesome 30 year old truck. There is a plate on the drivers side of engine-block just underneath the sparkplugs, and after isolating my oil leak to that gasket, I cannot find any information about what that plate covers and tightening specifications.
What is that cover/gasket called?
There are six bolts with rubber gaskets holding it to the engine block.
Should I replace the rubber gaskets too?
That's the pushrod cover, although I've also heard it referred to as a 'sideplate'. Mine's leaking oil from there as well - I haven't fixed it yet, but I did buy a new gasket from NAPA, and it came with the little rubber grommets/gaskets you mentioned. I might do it this weekend, since it's supposed to reach 60 degrees here.
I belive the name is: push rod cover, and the gasket replacement is a kit that includes the bolt gaskets. I had replaced mine with a Felpro kit I got at a local auto parts store. I used a bit of grease to hold the rubber gasket in place on the cover as it was repositioned on the block. Leak solved!
Good Luck!
HARFEND
Good Luck!
HARFEND
JustinP
07-23-2015 01:29 AM
1986F150six
08-21-2014 11:21 AM
joegeds
06-08-2014 03:18 PM
WoomaHodal
19
02-03-2007 02:32 PM
