New stall/stutter issue.
I've been having troubles with the truck recently. This time though, there's no Check Engine Light coming on.
The truck just stalls. Seems to stall more after it's been idling or low RPM for a bit. It generally stalls at low RPM and stutters at mid RPM acceleration. After it stalls, I need to step on the go pedal and turn the engine over, it will then start. Sometimes it stalls again, but most of the time is stays running. Sometimes it will run for a minute. Other times it runs for a half hour with no issue.
This new problem just started happening a couple days ago. I just got back from 12 hours of plowing snow. It stalled 30 or so times.
Here's a link to last weeks problem in case the two are related:
https://www.ford-trucks.com/forums/10...cal-issue.html
Should I just throw a rebuilt IDM in and see if that fixes it, or is there something better I can do instead of shotgunning parts at this?
When it stalls, is it like a sputter or is it exactly like if you shut the key off? I had a similar problem, and I replaced the CPS, and it fixed it. Mine was as if I shut the key off.
There's plenty of information on bad CPS's here and elsewhere on the internet, so you can look around and see if they're describing what you're experiencing.
Last edited by BuckHammer; 01-27-2011 at 02:17 PM. Reason: Used a period instead of a question mark.
Just went to move it into the shop. It didn't want to start. I'd crank it over, it would run, then stall. I finally got it to run and pulled it around and in the bay. I figured I'd grab my camera to give you guys video/audio of what's going on. Don't you know, I can't get it to act up@!#
I have a short clip of a very small instance of what's going on. Just above 1500 RPM there is a hesitation. When it's bad, it will bounce at that RPM and "sputter" or "stutter" etc, and not want to go above it. This is my first issue with a diesel, so in comparison it's like a hard spark cut on my turbo bmw.
YouTube - FILE0016
I'm going to change the fuel filter now. If I get better clips of it, I'll share with you guys.
YouTube - FILE0016
mine is doing exactly the same thing! i got done plowing went to my grandparents to snow throw their driveway left truck running in the street finished came back and truck was dead. this morning i went to start it in the driveway and the wts light flashed on and off and the relay under the hood was clicking. i finally got it going with a combo of starting fluid [i hate using!] and jump the glow relay it still shutters like its running on 5 out of 8 cyl. i got a few codes and a cel to come on 0603 and 0344 codes any ideas? the last thing i wanna play with after blowing a hydro line on plow tranny solenoids crapped out had to unplug tranny now this i will try filter and screen cleaning but why won't gpr work? please help need truck asap only vehicle i have
I'm a noob just like you it seems. I placed an order for a rebuilt IDM. Should be here Wednesday. The fuel filter didn't seem to help. Here's some audio of it happening:
YouTube - FILE0035
The check engine light is finally on again. This time, it still runs while the light is on.
Should I start a new thread with this video or does someone have an idea?
YouTube - FILE0035
0603 and 0344 were my codes I pulled internal control kam error what is that? I got like five codes total but the others I already know about my back press sensor is disconnected has been since I bought my girl. Cmp intermittent what is this! Those are my unknown codes! Am I looking at an idm too?
Just borrowed a friends MAC Taskmaster. Read all my old codes that I fixed without a tester. Cleared those. Ran the gamut on tests. Got a lot of clear tests. Drove around a few miles with not a single hick-up. Pulled into the garage bay to check something out..
Went under my truck and touched the CPS wires: the truck died.
