Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.7L Power Stroke Diesel 2011-2012 Ford Powerstroke 6.7 L turbo diesel engine SPONSORED BY:
  #46 (permalink)
Old 02-28-2011, 03:34 PM
scottjima scottjima is offline
Garage is empty, add now
scottjima is starting off with a positive reputation.
Thanks for all the great input here. I have a related question. I currently have an in-bed toolbox/tank which holds 45 gallons. It has a valve which switches between the factory and aux tank. It also switches the sending unit between the two tanks so the aftermarket tank is shown on the fuel guage when running from the aux tank.
I saw references to two sending units and two tank readings. This implies there is another set of wires to connect to another sending unit. Where and what color are these wires? Is there any programming to allow a second fuel level to display in the menus?
  #47 (permalink)
Old 02-28-2011, 04:05 PM
Marauder92V's Avatar
Marauder92V Marauder92V is offline
Marauder92V has a good reputation on FTE.Marauder92V has a good reputation on FTE.
Quote:
Originally Posted by rickatic View Post
That's interesting...wonder if the Fed's knew that...
They do now.
__________________
F350 4x4 Crew, Short Bed, Diamondback Tonneau, DuraFlaps, Ford LockPick, Extended Remote Start, DDM HIDs all around, Epic door seals
  #48 (permalink)
Old 02-28-2011, 04:15 PM
sdetweil's Avatar
sdetweil sdetweil is offline
1955 Ford F-100
My Garage
sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.
well, this implies that the computer was programmed to accept two input signals. it seems that the dual tank option was never actually developed, so the wires would not actually be there (I don't think, personally )..
Sam
__________________
55 F100 460/c6, 3.55ls - 436 hp, 489 tq
12 F250 4x4, SRW, 3.31, CC, SB 400 hp, 800 tq
08 F350 4x2, DRW, 4.10ls, CC, LB - sold
  #49 (permalink)
Old 03-03-2011, 07:21 PM
brmccolley brmccolley is offline
brmccolley is starting off with a positive reputation.
Titan Tank Installed
I contacted my usual dealership to schedule the PCM programming, but they said they couldn't change the fuel tank capacity. I have a call in to two more dealerships to find someone who knows what they're doing. In the meanwhile, I'll keep monitoring this thread until issue is resolved.
  #50 (permalink)
Old 03-03-2011, 09:13 PM
rickatic rickatic is offline
Temporarily Deactivated
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
The real fix for the 50 gallon Titan MTE readings is not ready yet.
__________________
Ricatic
2006 Chevy 3500 LTW 3500 Dually...the current Diesel Pickup Gold Standard
2011 F350 SRW CC SB 4WD Lariat 6.7 Gone bye bye
2009 Heartland Big Horn 3055 RL FIVER-Home away from home
2002 F150 Super Crew- Deb's truck
  #51 (permalink)
Old 03-04-2011, 12:19 AM
flaharleyguy flaharleyguy is offline
flaharleyguy is starting off with a positive reputation.
Quote:
Originally Posted by lexustbs View Post
I'm waiting to see if the calibration can be changed before I order mine. On another note while we wait, has anybody put off-road fuel in their truck? I'm pretty sure its the same stuff, just a different dye. And yes I understand why there is dye in there.....
I too would like to know other than the dye is there a difference in off road fuel? I understand why as well.
PS I'm waiting to order my 50 gallon tank until the issue is resolved as well
Thanks
  #52 (permalink)
Old 03-04-2011, 07:05 AM
I guess I do not understand the waiting to order the tank until the MTE calibration can be CUSTOM programmed for tank size. Everything works with the Titan tank installed except the computer does not know you have a bigger capacity. The fuel sending unit works perfectly. The trip computer figures fuel used and mpg as accurately as it did with the stock tank. I reset my Trip A computer at every fillup and it tells me all I need to know about how much fuel I have left. If the MTE reading accuracy is the only reason for not buying the tank now, I have to wonder if you really need the larger tank.
Regards
__________________
Ricatic
  #53 (permalink)
Old 03-04-2011, 07:33 AM
djousma djousma is offline
2011 Ford F-350
djousma is gaining momentum as a positive member of FTE.
I just wish the new tank was not $1000+....For me it would be just for the convenience of the capacity. I dont do too many long hauls with the TT.
  #54 (permalink)
Old 03-04-2011, 07:42 AM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
[quote=rickatic;10049428]I guess I do not understand the waiting to order the tank until the MTE calibration can be CUSTOM programmed for tank size. Everything works with the Titan tank installed except the computer does not know you have a bigger capacity. The fuel sending unit works perfectly. The trip computer figures fuel used and mpg as accurately as it did with the stock tank. I reset my Trip A computer at every fillup and it tells me all I need to know about how much fuel I have left. If the MTE reading accuracy is the only reason for not buying the tank now, I have to wonder if you really need the larger tank.
Regards[/QUOTE/]
Your right. I don't need the bigger tank. But I sure would like to have it. But being a want, I'm going to wait till all my gauge functions work before I do dive in. does anybody NEED this tank really? 300 miles is just about all I want to drive, then I need a stretch break. But at the same time I hate fueling, so this would eliminate the problem.
  #55 (permalink)
Old 03-04-2011, 07:59 AM
Yes, the capability is needed
There are plenty who transport horses or other cargo long distances across the country. It does help to have the flexibility to last through to a distant stop where the trailer can easily be manuevered through the parking lot rather than deal with what is immediately available. It's also very helpful during bad weather conditions. There are many other individual reasons, but those are just a couple.
  #56 (permalink)
Old 03-04-2011, 08:44 AM
I do get the 300 mile stops but with the stock tank that is beyond the range of safe feelings for me pulling my fiver. It also puts you at the mercy of the local fuel prices. Often I find less costly fuel within a hundred miles or so of where I had to stop or run out of fuel. While working in Indiana, I found a fuel stop that was 30 cents cheaper than any other fuel stop. I was there 3 weeks and saved almost $100 on fuel. I could make it home, 350 miles on less than a 1/2 tank, and the extra fuel when I got home would have cost me 40 cents a gallon more to put back in at fill up.
I also get the hesitation on the $1000 price. I posted here before I bought the tank that I was choking a little on the price. I have no regrets about taking the $900 pre-production pricing plunge. I am extremely pleased with my Titan Tank. I guess that makes it worth what I spent. YMMV
Regards
__________________
Ricatic
  #57 (permalink)
Old 03-04-2011, 11:24 AM
Regards
I think some people, including myself, want to see things work the way they were intended to work. May sound silly, but there are a number of people who think this way.
__________________
  #58 (permalink)
Old 03-04-2011, 12:25 PM
Quote:
...count me in as one of those types as well...and the factory tank sizes work well with the MTE calculations...the difference here is Ford did not make provisions in the software to provide for aftermarket tank sizes. The ability to do so was added in February of this year by Ford to graciously accommodate a request for this capability. Paul Bruckne hand carried the request to the Ford programmers. He did not get what he asked for and has returned for another shot at it. Ford is certainly not obligated in any manner to give the aftermarket tank owners a custom programming capability, but it would be nice.
I guess I bought my Titan tank not anticipating any help from Ford so my situation is different...but if I had to do it over again, the tank is worth it to me. I have not seen any of the current owners of these tanks complaining about a hardship with the MTE calculations...maybe I missed something
Regards
__________________
Ricatic
  #59 (permalink)
Old 03-04-2011, 12:42 PM
I think in your case function outweighed form. The value of the tank outweighed the minor inconvenience of the MTE presentation. Some of us **** rententive types want both! Same reason I held out buying an iPad until it had the cameras!
__________________
  #60 (permalink)
Old 03-04-2011, 12:47 PM
6.7 hillybilly 6.7 hillybilly is offline
6.7 hillybilly is starting off with a positive reputation.
I to have the Titan tank, love it.. Like Ricatic the MTE is not a big deal. Just set trip A and I'm good to go. Sure the $1,000.00 is a lot but I would spend it again in a heart beat. The fit and finish of the Titan tank is 2nd to none. So if your wanting the Titan tank go for it, I'm sure Ford will have the MTE worked out some time.
Tags
2011, 67, 7102, articles, bad, calibration, capacity, diesel, f350, ford, fuel, ids, news, size, tank, trucks, update
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
