Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 01-27-2011, 11:43 AM
rbenton rbenton is offline
Garage is empty, add now
rbenton is starting off with a positive reputation.
Coolant smell from the heater/defroster
My 2000 Ranger (3.0/5spd) started blowing the smell of colant through the vents and is fogging up the inside windows. Could this be a bad heater core or????? Any ideas??? If anyone knows of a thread that already discussed this please try to send it to me...Thanks!!!!!
__________________
Richard Benton
00 Ranger 3.0
72 F100 Short Bed 302
72 Gran Torino Fig 8 (RIP)
48 Cushman (Project)
  #2 (permalink)
Old 01-27-2011, 11:51 AM
duhkrafties duhkrafties is offline
duhkrafties is starting off with a positive reputation.
Most definetely sounds like a bad heater core. I have replaced several of these for the same concern. You will more than likely see coolant dripping from the drain tube located in the plenum part of the heater case that is mounted to the firewall if the leak is bad enough. Doing a heater core in your truck will require removal of the dash and the heater plenum in the engine compartment.
  #3 (permalink)
Old 01-27-2011, 12:24 PM
Great........doesn't sound like very much fun...oh well!! Thanks for the input!
__________________
Richard Benton
00 Ranger 3.0
  #4 (permalink)
Old 01-27-2011, 12:30 PM
They arent to bad if you have some good mechanical knowledge, patience, and the right tools. I've done a few and have it down to about 2-3hours.
Good Luck
  #5 (permalink)
Old 01-27-2011, 02:19 PM
FordNFishinLover's Avatar
FordNFishinLover FordNFishinLover is offline
FordNFishinLover is starting off with a positive reputation.
Yep, most definitaly at heater core. Oftenly you will see it drip on the passengers side floor mat.
Never changed one on a ranger, but my old ford pickup id done in about an hour. Imagine things are a bit tougher on these trucks though.
__________________
1981 Ford f-100 302/C6/9'' 3.50 limted slip/31x12.5
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
  #6 (permalink)
Old 01-29-2011, 09:31 PM
4x42001 4x42001 is offline
4x42001 is starting off with a positive reputation.
Be glad the heater core isn't in a dodge dokota.
  #7 (permalink)
Old 01-29-2011, 10:45 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave Flexfuel-Dave is offline
Flexfuel-Dave is gaining momentum as a positive member of FTE.
Quote:
Good Luck
Don't go bragging about this! You'll soon see a pile of older Rangers and their owners in front of your place looking for you!
  #8 (permalink)
Old 01-30-2011, 08:41 AM
smalltrucker's Avatar
smalltrucker smalltrucker is offline
smalltrucker is starting off with a positive reputation.
Be thankful you live where it's warm. I had a complete sudden failure at around zero, the warm moisture froze on the windows instantly. Good luck, been lucky here and never changed on on a Ranger (yet).
DAve
  #9 (permalink)
Old 01-31-2011, 10:30 PM
D-mon D-mon is offline
D-mon is starting off with a positive reputation.
my 2004 4.0 ranger kinda has a burning rubber smell when i start it up now in the winter here in MN. The smell is in the cab and kinda even outside of the truck.
cant off the top of my head remember what the smell of antifreeze smells like.
thanks guys
__________________
2012 F-150 FX4 EcoBoost Crew Cab
2004 Ford Ranger XLT 4x4
1999 Ford F-450 4x4,V-10, diamond tool box, then dump contrators box behind that. Also BOSS V-plow
1979 Ford F-150 Custom! 4x4
  #10 (permalink)
Old 02-01-2011, 09:38 AM
Quote:
LOL. I'll do those heater cores all day long. Not sure that its worth the drive to Michigan though. LOL
  #11 (permalink)
Old 02-01-2011, 09:40 AM
thanks guys
Coolant usually has more of a sweet smell to it. I dont think it would really be associated with any kind of burnt rubber smell.
  #12 (permalink)
Old 02-01-2011, 11:05 AM
ok thanks.....
no it really doesnt have a sweet smell to it. What else could it be?
thanks guys
__________________
  #13 (permalink)
Old 02-05-2011, 06:34 AM
Rackster's Avatar
Rackster Rackster is offline
2000 Ford Ranger
Rackster is starting off with a positive reputation.
Heater Core
Confirming the posts above, it's likely your heater core. I had a Buick Skyhawk back in college that would break the passengerside motormount. When the engine torqued, it would tug on the hoses to the heater core causing the stems going into the core to snap at the weld. Sticky windshield film, smell of antifreeze, and a puddle on the passengerside floormat. I broke mounts and heater cores with regularity - got pretty good at doing things by feel (motor mounts) and on the fly with the heatercore. Like my fellow colleagues above, things seem to break on the coldest day of the winter! You might be able to grit it out for a few days to line up the time you need to do the job yourself. Keep a short handled scraper for the inside of the windshield and if you can, connect the input hose to the output hose to bypass the heater core althogether (I would use the broken stem for the bypass slipping it into the return hose and clamping off). Either find a buddy's garage you can borrow if you don't have your own, or contemplate a cold trip to see duhkrafties in Michigan. Good Luck!!
  #14 (permalink)
Old 02-05-2011, 06:44 AM
Rackster's Avatar
2000 Ford Ranger
Burning Rubber Smell
D-mon,
Does it smell electrical, like burning insulation? It could be you have a short in a wire/wire harness, so exercise caution. Where are you detecting the odor?
Rackster
  #15 (permalink)
Old 02-05-2011, 03:27 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to all
Good Luck
Experience is always a time saver. Realistically, for a first-timer, it will take longer than that.
The heater core is inside the plenum. THIS post provides good info on how to gain access to the plenum.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
Tags
2000, 54l, antifreeze, coolant, defrost, defroster, fog, ford, heater, navigator, odor, ranger, running, smell, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
