Tips for bleeding hydraulic clutch? - Ford Truck Enthusiasts Forums
Old 01-27-2011, 10:58 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I am putting a 460 with ZF 5-speed in my F150 and one of the things I am running up against is bleeding the hydraulic clutch. This has the external slave cylinder. On the previous setup, with the internal slave, you just gravity bled it a bit and you were good to go. Not so on this one, the fluid barely comes out, like 1 drip every 10 minutes. I have tried bleeding it like you do brakes, with one person pumping the pedal and then releasing the bleeder, this did make it better, but it still has quite a bit of free travel at the top.
I looked up the procedure in my Ford manual and it says to disassemble the whole apparatus and then fill the slave with fluid and reassemble. What the heck is the bleeder screw for, then?
Anyone done this successfully? I have never had to pressure bleed a hydraulic clutch before, they usually just gravity bleed. Should I use a vacuum pump? TIA for any help.
Old 01-27-2011, 11:02 AM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
I would say go buy one of of those hand bleeders from the lps. I used one and it worked like a dream and it's good for other applications
Old 01-27-2011, 11:47 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/55...-a-clutch.html Some ideas for you in this thread.
Old 01-27-2011, 01:17 PM
jas88's Avatar
Thanks, Lazy K, I admit I did not do a search first before posting. I think I have enough clutch to drive it, I guess I will try the bumpy road approach first since that is pretty easy.
Old 01-27-2011, 07:34 PM
USMC0351fordtruckin USMC0351fordtruckin is offline
USMC0351fordtruckin is starting off with a positive reputation.
my truck sat for a while and the clutch would en-gauge so i ask my dads buddy who owned a garage in his younger days and he said pump it 50 times with one leg and another 50 times with the other and it should work so i tried it and it did....
Old 01-27-2011, 07:51 PM
91chevywt's Avatar
91chevywt 91chevywt is offline
91chevywt is gaining momentum as a positive member of FTE.
For my mazda transmission, I used a vacuum pump with a cup inline of the suction line. Vacuum pumps can be pretty handy to have around, I use mine for stubborn brake lines that I just can't get the air out of with a gravity bleed and it works pretty well.
If you have air in the master cylinder, with the bleeder closed, if you pump the clutch pedal up it should help get air out. You may have to do this for a while. In my experience with automotive hydraulic systems, when there is no fluid coming out of the bleeder there is probably a large amount of air in the system. As you get the bulk of the air out, the fluid should flow pretty steadily when the bleeder is open.
Old 01-27-2011, 08:04 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I have read that the easiest way to bleed the external slave is to take it off of the engine, hold it with the hose-end up and move the slave piston by hand through the full stroke a few times.
Old 01-28-2011, 08:45 AM
jas88's Avatar
That's what the Ford manual says but getting that little roll pin out so you can release the line is a PITA. I can't see how taking the thing apart is not going to introduce more air to the system, tho.
Old 01-28-2011, 08:55 AM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
When you push the clutch in, the bleeder should be open, when you let it out, it should be closed. it should take two people to do it.
Old 01-28-2011, 07:52 PM
EPNCSU2006's Avatar
Leave the hydraulic line connected during the process. Like you said, it really won't do any good if you have to open the system again after bleeding.
Old 01-30-2011, 10:13 AM
nate0031 nate0031 is offline
nate0031 is starting off with a positive reputation.
I just bled my 96 zf5 clutch. I simply loosened the bleed screw on the slave and had someone else press the clutch slowly, closed the valve, and repeated several times. This was all done with the master and slave installed on the truck. I used a torx t25 to loosen the bleed screw, although I'm pretty sure it's actually an Allen. The clutch went from completely non-functional to working properly in 15 minutes. If some slaves do not have bleed screws, I don't know what to do then, lol.
The forever question: How the heck do I get my clutch bled?? bluemtn95ford Ranger & B-Series 3 04-05-2015 06:37 PM
2001 Escape - How to bleed clutch slave cylinder cinbearcat Escape & Escape Hybrid 2 11-30-2013 05:52 PM
how to bleed clutch hotrod91174 1987 - 1996 F150 & Larger F-Series Trucks 8 09-18-2012 01:52 PM
How to bleed master/slave clutch cylinders 89nolaf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-31-2010 01:37 PM
Hydraulic Clutch System Bleeding sauced1173 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 07-17-2006 09:07 AM
Tags
1991, 1997, 1999, 2000, bleed, bleeding, clutch, duty, f350, ford, heavy, hydraulic, super, truck, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
