Clearing trouble codes - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-27-2011, 10:02 AM
r stene r stene is offline
r stene is starting off with a positive reputation.
Thanks for everyones help,One more ?, When clearing codes by unhooking the battery,will it shut off the light and clear codes or do I clear it with my scanner.
Old 01-27-2011, 12:10 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Either one will clear the code, but removing the battery B- cable also clears the KAM (Keep Alive Memory).
So, the computer will have to relearn some new things, like it's cold & warm idle strategy & it'll have to begin to build new fuel trim tables, as they are wiped with a battery cable disconnect.
It'll also have to be driven through a certain routene for the IM monitors to reset, so it'll be ready for emissions testing.
If you don't need to have emissions testing done right way, then the IM monitors will reset over time, after enough driving is done.
If you use your scan tool to erase the code, it won't mess with the KAM, so all of the above is avoided.
OBD II CODE CLEARING 97' Ford Explorer V6 4.0SOHC 97' DieHardExploder Explorer, Sport Trac, Mountaineer & Aviator 2 10-31-2014 05:20 PM
EGT sensor shut down question jonrjen 6.7L Power Stroke Diesel 5 11-07-2013 09:03 PM
Code P0401-Unplug EGR-Now code P0403, P0405 weberr7 6.0L Power Stroke Diesel 10 07-02-2012 04:22 AM
XZTS harness simsbud 6.0L Power Stroke Diesel 3 07-03-2011 06:49 PM
code 0069 modular2v 6.0L Power Stroke Diesel 2 02-12-2011 11:33 AM
Tags
2004, 60l, battery, clear, clearing, code, codes, engine, f150, fault, ford, monitors, ranger, trouble, unhooking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
