a/c Stuck in defrost mode - Ford Truck Enthusiasts Forums
Old 01-27-2011, 09:50 AM
murrayvlow murrayvlow is offline
murrayvlow is starting off with a positive reputation.
Can someone explain to me how to fix my aircon as it will not blow from the front vents anymore - all it is blowing is hot air through the window defost mode, if possible can someone ford me a picture on where to locate the vacuum as i have been told to check the lines coming of it at that can cause this problem
Old 01-27-2011, 10:39 AM
Justin's Green Truck's Avatar
Justin's Green Truck Justin's Green Truck is offline
Justin's Green Truck is starting off with a positive reputation.
The air distribution doors I think operate from vacuum solenoids under the dash. I would probly pull that lower cover off down near the transmission tunnel and see if, when you move the distribution switch, anything happens. If it doesnt, pull the vac line off and see if you're getting vacuum with the engine running. If you are, then it might be the switch itself. If not, trace that vac line to find the problem.
Dont know if you have the all electrical heater control panel or the one with three dials. The one with the three dials has vacuum lines running into the back of it that you should probly take a look at.
Old 01-27-2011, 10:44 AM
Heres a pretty good thread about this issue i think. It says that the default setting is defrost only if you lose vacuum. maybe it will help you find your problem.
http://www.ford-trucks.com/forums/87...e-defrost.html
Old 01-27-2011, 11:15 AM
SteevenH SteevenH is offline
SteevenH is starting off with a positive reputation.
Check behind your battery box for a broken or kinked vacuum line running through the firewall of your vehicle from the vacuum reservoir. Defrost is indeed the default position when vacuum is lost. Behind the battery box is usually the culprit.
Old 01-27-2011, 02:19 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
See FAQs in HVAC forum.
Old 01-28-2011, 07:49 AM
Thanks for your feedback
we found the problem today. One of the vacuum lines on a spliter was damaged (like it had been burnt) replace the damaged line and all now works fine.I think it is working alot better then before. The cab seem to get cooler alot quicker
Once again thank for you feedback
Old 01-28-2011, 08:28 AM
Glad you fixed it!
Was is the splitter behind the battery, like near the firewall? Or that one that sits nearer to the engine
Old 01-28-2011, 08:36 AM
it was located the firewall
hard shifting e4od with newly rebuit trans coreyw2 1994.5 - 1997 7.3L Power Stroke Diesel 2 12-05-2015 05:52 AM
heater blows defrost only FishnDaddy Excursion - King of SUVs 5 06-19-2011 11:41 PM
A/C not always cooling mbjones99 1999 to 2016 Super Duty 5 06-19-2011 10:06 PM
TBC mode LI Happy Camper 6.7L Power Stroke Diesel 1 06-12-2011 04:10 PM
Valet Mode Y2KPSD 6.7L Power Stroke Diesel 6 01-04-2011 11:20 PM
Tags
2003, 68, 99, defrost, defroster, engine, f150, f350, ford, international, mode, stuck, taurus, truck, v10, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
