V band exhaust clamp
Old 01-27-2011, 08:10 AM
redman84's Avatar
redman84
redman84 is offline
Where can one find them at? I need a new one for my dp to ebpv housing. Its kinda loose and leaking exhaust.
Old 01-27-2011, 08:23 AM
jg96powerstroker's Avatar
jg96powerstroker
jg96powerstroker is offline
dude i seen them on ebay, napa can get them to
Old 01-27-2011, 12:30 PM
Desert Rancher's Avatar
Desert Rancher
Desert Rancher is offline
This place has everything related to hardware.
McMaster-Carr
Old 01-27-2011, 05:03 PM
redman84's Avatar
redman84
redman84 is offline
Maybe yall can advise a bit more. I can find plenty with the flat bands but the one i need has the internal ring that holds flanged pipe together. I'm having some trouble finding it. Maybe theres a different name for it?
Old 01-27-2011, 05:38 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
I just spend a good 20 min searching for you... in the shop manual it just says "5A231 pipe yoke clamp" But most of the clamps that have that number are IC boot clamps... Nice Job Ford
Old 01-27-2011, 06:08 PM
redman84's Avatar
redman84
redman84 is offline
Thanks for looking man. I've been doing the same. Oh well. Hey what's a hotfoot?
Old 01-27-2011, 06:19 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Ah yes... the illusive hotfoot mod! LOL, It's just another way of saying I fixed the crappy response of the TPS and IVS, and tweaked the TPS so at WOT it's actually WOT. Pretty much useless being in my sig..
See here sir for a full .pdf with instructions and pictures
https://www.ford-trucks.com/forums/1...-makomark.html
Old 01-27-2011, 07:01 PM
BadDogPSD's Avatar
BadDogPSD
BadDogPSD is offline
The are also called V Band clamps or flanged exhaust clamps.
Summit Racing sells them too.
Old 01-27-2011, 07:23 PM
Desert Rancher
Wow, those V clamps are not cheap!
Old 01-27-2011, 08:28 PM
redman84's Avatar
redman84
redman84 is offline
Greeeaaaat
Old 01-27-2011, 08:36 PM
BadDogPSD's Avatar
BadDogPSD
No they are not! $30-60 range...
Old 01-27-2011, 09:46 PM
wheelie31's Avatar
wheelie31
wheelie31 is offline
well i lost my t bolt and i just used a bolt and its been holding for months with no problem. if u just need the t part you could alway weld one up with some all thread, I was gonna do this but the bolt i used held.
Old 01-27-2011, 11:43 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Old 01-28-2011, 06:14 AM
redman84's Avatar
redman84
redman84 is offline
Thanks guys. Maybe I can find a t bolt somewhere or a regular bolt that will fit. The clamp is fine the threads on the bolt are just f'd
Old 01-28-2011, 11:02 AM
redman84's Avatar
redman84
redman84 is offline
So I'm finding the clamps and yeah they are expensive. What size is the DP/EBPV housing joint? Is it a 3" pipe right there?
Quick Reply: V band exhaust clamp
