5.4 engine miss - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5.4 engine miss
Old 01-26-2011, 09:22 PM
brentaleclaire brentaleclaire is offline
brentaleclaire is starting off with a positive reputation.
5.4 engine miss
Recently my 99 f250 super duty developed a miss,no check engine lights came on,but after hooking up a portable scan tool, I found a code . The code showed a misfire on cylinder 8. I changed the plug and coil pack ,but I still have the miss.I then pulled the plug wire and hooked to a new plug and could see a good spark. The scanner still shows a miss on #8. Anybody have any ideas?
Old 01-27-2011, 07:21 AM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
Injector or low compression?
Tags
01, 1999, 2010, 54, 99, computer, engine, expedition, f250, ford, miss, misses, missing, motor, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
