1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2014, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Brake fluid leak HELP!!
Old 01-16-2011, 07:02 PM
lukedncn's Avatar
lukedncn
lukedncn is offline
i have a 2000 f250 7.3 ltr diesel with 133000 miles...there is a brake fluid puddle on my driveway coming from fluid leaking on the driver side under the hood somewhere...i cant pinpoint the leak but the wiring harness that plugs into the abs sensor is wet. The fluid falls down onto the inside wall of my tires and it flings it into my finder well...it seems like it only leaks when its really cold outside...i do live in louisiana so cold is like 30 degrees...anyone else experience this problem? what do i do before i have to spend a bunch of money just for someone to tell me what is wrong? Cant find the leak
Old 01-16-2011, 08:51 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
How do you know it is brake fluid?
Was it just spilled and could it be nothing wrong?
At least, post pics, color of fluid, odor etc.
Could it be ATF? / PS? fluid?
Old 01-26-2011, 09:13 PM
lukedncn's Avatar
lukedncn
lukedncn is offline
it is definately brake fluid...i have had to add to the resovoir a couple of times through out the last few weeks...i dont know what it can be? should i change out the master cylinder and go from there?
Old 01-27-2011, 02:06 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
What side wheel is fluid on the sensor? If its driver side, it could be master cylinder. Really common for seals to go out in them when weather changes.
Should be evidence running down brake booster where master cylinder attaches.
Could be caliper, if thats the case, the inside of the wheel would be all wet.. Could be brake line to caliper. Just about everything would be wet near it but should be able to see with someone pressing on the brakes.
Be careful.....brake fluid is extremenly flammable and will burn that truck up quickly if it mists to a hot exhaust component
spongecop
02-03-2018 09:43 PM
bullsmack
05-18-2014 06:13 PM
gdellinger1
01-25-2014 08:36 PM
Bigrock3190
6.7L Power Stroke Diesel
03-24-2011 10:29 PM
imlowr2
10-10-2007 08:22 PM
Quick Reply: Brake fluid leak HELP!!
