03 F150 PCV VALVE LOCATION??? - Ford Truck Enthusiasts Forums
Old 01-26-2011, 07:24 PM
sealtech101 sealtech101 is offline
sealtech101 is starting off with a positive reputation.
Can anyone tell me where this Pcv valve is located. Most answers I'm getting is pass. side valve cover, this is not true UNLESS ford made this thing different.( like no other normal pcv valve) Thank you for help.
[/IMG]ealtech101/100_1951.jpg[/IMG]
Old 01-27-2011, 11:15 AM
Justin's Green Truck's Avatar
Justin's Green Truck Justin's Green Truck is offline
Justin's Green Truck is starting off with a positive reputation.
Which engine do you have?
Some of these trucks use a pcv valve that is very different from what you're used to. It still goes in the valve cover but has a square base and you turn it 1/4 turn to get it out.
Old 01-27-2011, 11:27 AM
If not there, follow the hose from the pass side valve cover to where it meets the intake. Some of them are bolted in right there and have coolant hoses connected to them as well.
Old 01-27-2011, 03:29 PM
i have 4.2 v6
Old 01-27-2011, 03:46 PM
Well, you figured anything out yet?
Old 01-27-2011, 03:51 PM
If im not mistaken, thats it in your second and third picture. Should be two bolts or screws on the intake where that hose with the foam insulation and the cooler line go in. Try unbolting that and see if it isnt inside. They look like torx screws from the picture
Old 01-27-2011, 07:37 PM
I will look and let you know if that is it
Bye Bye Front Drums ultraranger 1967 - 1972 F-100 & Larger F-Series Trucks 608 10-04-2016 03:45 PM
Truck Horns ultraranger 1967 - 1972 F-100 & Larger F-Series Trucks 7 03-08-2015 07:29 PM
Ford Engine Oil Cooler Filter Adapter ultraranger 1967 - 1972 F-100 & Larger F-Series Trucks 17 12-01-2014 09:25 PM
Neutral Safety Switch C-4 ultraranger 1967 - 1972 F-100 & Larger F-Series Trucks 16 11-30-2014 12:35 AM
Intercooler Install OBS Ford (Pic heavy) Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-09-2014 10:43 AM
Tags
2003, 2004, 385, 40, 460, davidson, f150, foord, ford, harley, location, navigator, pcv, pvc, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
