6.2 cam sensor on a 2011 f250
Not sure if you found them, I'm doing mine now, they are located at the back, If you look at your valve cover the are just on the inside of the last valve cover bolt at the top, 8 mm socket to undo the bolt, i left wiring attached till i got it out to have something to grab then unclipped it. The o-ring makes it a bit tight coming out so I used a flat head screw driver between the sensor and head to get it to pop up. do this gentley you don't want to break it off in the head. I attached pics of drivers side. Passenger side is tougher more stuff in the way same location on passenger head. On Passenger side I removed the hose going to the valve cover unplugged the last coil and injector and had enough room to get in and get it. Hope this helps.
this is looking in past the master
this is zoomed in from the first pic, you can see the last valvcover bolt on top
that is the driverside cam sensor
rideracelivemx7
04-26-2009 07:32 PM
