Heater blower only working on high - Ford Truck Enthusiasts Forums
Old 01-26-2011, 09:38 AM
gt4660 gt4660 is offline
gt4660 is starting off with a positive reputation.
91 F150 351.
My heater blower only works on high. Vent, floor or defroster all the same.
So the question is what controls the blower and what are some trouble shooting ideas? Or has anyone had this issue before?
Old 01-26-2011, 09:45 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
blower motor resistor is out... $10-$15 and 15mins to change..
MOTORCRAFT Part # YH1698
DORMAN Part # 973011
Old 01-26-2011, 04:09 PM
Awesome, Wheres it located?
Thanks for the information!
Greg
Old 01-26-2011, 04:26 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
It's right next to the blower motor-it has a wire harness that plugs into it.
Old 01-26-2011, 04:33 PM
nstueve's Avatar
PS if you get the cheap one at the part store spray the coils with some clear aerosol sealant.... That will keep the rust and water off the coils for a few extra years. You don't need to do it heavy... just a light dusting to keep moisture off them.
Old 01-27-2011, 05:48 PM
Nstueve,
Thanks for the info. Swapped it out today and all is good!
Old 01-27-2011, 08:20 PM
ravens fan's Avatar
ravens fan ravens fan is offline
ravens fan is starting off with a positive reputation.
i have the same problem... where exactly is the blower motor located?
Old 01-27-2011, 10:48 PM
raptor1971's Avatar
raptor1971 raptor1971 is offline
raptor1971 is starting off with a positive reputation.
The blower motor is under the hood. It is next to the heater hose on the right side of the engine compartment and like said above the blower motor resistor is right next to the blower motor.
Old 10-26-2011, 04:12 PM
The new resistor only lasted about a month. (Never got around to posting) So I am going to buy a new one now and what type of spray do I use on it to make it last longer?
Old 10-26-2011, 04:38 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Spray?
Old 10-26-2011, 04:44 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Spray??? If a new resistor unit only lasted a month I'll bet your motor is getting old and the bearings are dry causing the motor to pull too many amps...
You can try to oil the bearings if you want but it won't last long....
Old 10-27-2011, 09:02 AM
nstueve's Avatar
yes guys, SPRAY! LOL...
The only reason I spray mine with a light layer of clear coat (or wild dog 40 depending on what i have at hand). It helps keep the salty wet conditions off the coils that go inside the heater housing. I have had a couple fail within 3-4 years on me, so I coat the coils to prevent the coils from rusting so quick (it could be b/c I am buying the cheapest resistors too ).
That being said the clear coating only helps to keep the resistor coils from rusting... You shouldn't be having a resistor fail within a month! How do you know it's the resistor failing???
Old 11-29-2011, 01:00 PM
How do I know its failing... When the fan only works on high, I replace that part and it works at all sopeeds. Lol. The truck hasnt been used much since the part was replaced. But I did notice some noise from the fan motor the last time I drove it. i will have to take a look.
Blower motor only works on high RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 2 01-06-2016 06:11 PM
Blower Fan only works on high setting dave3406 1999 to 2016 Super Duty 4 11-02-2010 07:22 PM
AC/Heater fuse blowing on high smokeyb97 1973 - 1979 F-100 & Larger F-Series Trucks 18 10-31-2010 07:26 AM
BLOWER MOTOR bigred00 1999 to 2016 Super Duty 0 11-18-2009 01:05 PM
Heater blower only high nickh 1987 - 1996 F150 & Larger F-Series Trucks 10 02-01-2009 08:43 PM
Tags
1996, 2004, 2007, blower, duty, f150, f250, f350, ford, heater, high, motor, operates, super, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
