Power mirror memory
Thanks! I get it all installed on Wednesday and then I'll have the receipt with part numbers but if I were to guess, the mirrors probably run around $300-400 each and the PCM is probably about a $100-150 part. Labor is per your dealership or shop unless you do it yourself and, honestly, it seems pretty easy to do yourself lol stay posted until Weds and I can give you a good answer.
I found these two Ford Technical Service Bullitins, but so far not able to find the whole report.
I did find the following link where the reports can be ordered: Search for a Service Bulletin | Safercar.gov | NHTSA
Vehicle: 2003 Ford Expedition
Nature of Defect: VISIBILITY:REARVIEW MIRRORS/DEVICES
Bulletin Number: 16675
Bulletin Date: Mar 2003
Summary: REVERSE TILT-DOWN MIRRORS NOT RETURNING TO THE PRE-REVERSE POSITION AFTER SHIFTING TO REVERSE AND THEN TO DRIVE. ( NHTSA ITEM NUMBER - 10001933 )
<HR>
Service Bulletin Number: 042116
NHTSA ID #: 10013389
Bulletin Date: Mon, 11/01/2004
Failing Component(s): 135000 VISIBILITY:REARVIEW MIRRORS/DEVICES
Summary: REVERSE TILT MIRROR SYSTEM DIAGNOSTICS AND REPAIR. *EH
<!-- /node-inner, /node -->
<HR>
Part Numbers
Seat memory module:
5L1Z*14C708*AA - processor - seat memory 12651D7 module
Mirror motors:
6U5Z*17D696*D - motor assembly 17707BT exterior mirror glass
Hope that helps some of you guys out. So far my mirrors aren't going straight up when I hit unlock so that's a good sign
(this is for an 03-06 body style, not sure if it changed for 07+)
Mirror motors:
PSD666
1999 to 2016 Super Duty
10-13-2016 04:23 PM
