1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Upper console removal
Old 01-26-2011, 07:09 AM
ResJudicata's Avatar
ResJudicata
ResJudicata is offline
My compass and thermometer are dead in my upper console of my '02 Exp. I have seen the threads on the likely cause of this. The capacitor and resistors coming loose or going bad. I can fix the electronics when I get to them. But, I need to make sure I'm taking the upper console down properly so I don't break anything.
How specifically do I get the upper console down? I see one screw inside the sunglasses compartment. Also, there are two covers that look like screw covers in front of the sunglasses compartment halfway between it and the compass. Do I need to take any screws out or just pull down on the console from the front working back?
I want to be careful as it is still cold here and that makes the plastic more brittle. Thanks for any help.
Chris
Old 01-26-2011, 12:11 PM
Londart's Avatar
Londart
Londart is offline
http://ww2.justanswer.com/uploads/fo...2_heADLAMP.pdf
look @ page 7....detailed instructions
Old 01-26-2011, 01:18 PM
ResJudicata
Thanks. So, it looks like it just pulls straight down?
chris
Old 01-26-2011, 03:56 PM
Londart's Avatar
Londart
Londart is offline
chris
after you pull the screw then ya pull down to release the clips then down and back to remove
Old 01-27-2011, 05:18 AM
ResJudicata
Great, thanks for the help.
chris
Old 02-18-2011, 03:06 PM
ResJudicata
Well, thanks for the help. I finally got this done. Easy as pie to get the console down. I just wanted to wait for the outside temp to get higher so the plastic would not be as brittle.
One of the surface mount resisters had broken loose as referred to in another thread. Got that resoldered and touched up some poor soldering from the factory. The thermometer and compass work great again.
Chris
dramirez163
1999 to 2016 Super Duty
06-27-2015 09:44 AM
jhcorley
03-27-2015 09:06 AM
flybaby_3
11-03-2014 06:08 AM
2007E150
02-04-2014 08:34 AM
Quick Reply: Upper console removal
