Upper console removal - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-26-2011, 08:09 AM
ResJudicata ResJudicata is offline
ResJudicata is starting off with a positive reputation.
My compass and thermometer are dead in my upper console of my '02 Exp. I have seen the threads on the likely cause of this. The capacitor and resistors coming loose or going bad. I can fix the electronics when I get to them. But, I need to make sure I'm taking the upper console down properly so I don't break anything.
How specifically do I get the upper console down? I see one screw inside the sunglasses compartment. Also, there are two covers that look like screw covers in front of the sunglasses compartment halfway between it and the compass. Do I need to take any screws out or just pull down on the console from the front working back?
I want to be careful as it is still cold here and that makes the plastic more brittle. Thanks for any help.
Chris
Old 01-26-2011, 01:11 PM
Londart's Avatar
Londart Londart is offline
Londart is starting off with a positive reputation.
http://ww2.justanswer.com/uploads/fo...2_heADLAMP.pdf
look @ page 7....detailed instructions
Old 01-26-2011, 02:18 PM
Thanks. So, it looks like it just pulls straight down?
chris
Old 01-26-2011, 04:56 PM
Londart's Avatar
Quote:
chris
after you pull the screw then ya pull down to release the clips then down and back to remove
Old 01-27-2011, 06:18 AM
Great, thanks for the help.
chris
Old 02-18-2011, 04:06 PM
Well, thanks for the help. I finally got this done. Easy as pie to get the console down. I just wanted to wait for the outside temp to get higher so the plastic would not be as brittle.
One of the surface mount resisters had broken loose as referred to in another thread. Got that resoldered and touched up some poor soldering from the factory. The thermometer and compass work great again.
Chris
2010 F350 Overhead console dramirez163 1999 to 2016 Super Duty 0 06-27-2015 10:44 AM
Overhead Console-Excursion vs Expedition jhcorley Excursion - King of SUVs 4 03-27-2015 10:06 AM
Ex overhead console display, lie-o-meter removal not the same as the one in the tech folder EXv10 Excursion - King of SUVs 9 11-19-2014 03:16 PM
Installing an overhead console. flybaby_3 1999 to 2016 Super Duty 11 11-03-2014 07:08 AM
Console ? 2007E150 1968-2013 Full Size Vans 12 02-04-2014 09:34 AM
Tags
04, 06, 2000, 2003, 2011, connect, console, expedition, f150, f350, ford, info, removal, remove, transit, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
