Advancing cam timing
Old 01-25-2011, 08:48 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Excuse this old V8 convert for another silly question, but advancing the cam is so easy on a SBF. There are dozens of timing sets for a SBF that will let you advance or retard the cam timing. Didn't see anything comparable for the 300 at Summit.
So to advance the cam on a 300, is it just a matter of slapping on degree wheel on the cam and turning it x degrees and slipping on the gear? I'd like to advance the stock cam until I'm ready to build a new engine and installing a new steel timing gear set is a good enough excuse if it's that simple.
Old 01-25-2011, 11:48 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
I've asked previously about cam "indexing". Never really got an answer.
I know that most non-stock V8 cam grinds come with a spec sheet that calls for the cam to be indexed at a certain degree, but no clue about aftermarket cams for the I6. I assume it could be done, thru the use of offset keyways. Can't say I've ever seen cam or crank gears for the 300 with multiple/offset keyway slots, like the SBC and SBF stuff does.....
Old 01-26-2011, 08:56 AM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
Cloyes does have a multi index gear set. It allows -4*,0, or +4* timing.
Old 01-26-2011, 11:11 AM
Rogue_Wulff
That, along with a set of 1-3* offset keys, should allow for practically any cam index setting.
Who carries this cloyes gear set?
Old 01-26-2011, 12:01 PM
nevrenufhp's Avatar
nevrenufhp
Any performance shop(summit, Jegs, PAW, etc.), and even NAPA(napa uses cloyes number).
8-1014 is the Cloyes number
Old 01-26-2011, 08:12 PM
BaronVonAutomatc
Very groovy, thanks. For what ever reason that didn't come up when I searched.
Big-worm
01-28-2011 08:08 PM
BaronVonAutomatc
01-04-2011 05:42 AM
74highboy
02-01-2010 06:40 PM
RCrawler
24
04-20-2009 12:25 AM
w-i-l-l-i-e
02-04-2009 12:33 PM
Quick Reply: Advancing cam timing
