Dome Light Problem Wont Turn On - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-25-2011, 07:42 PM
garsm garsm is offline
garsm is starting off with a positive reputation.
2001 f350 powerstroke.
My dome light wont go on, is there a relay or something I should check? I checked all the 5 and 10 amp fuses and they were all good. It doesnt come on when i open the door or spin the switch to turn it on. Its not the bulb because the bed light doesnt come on either and there is not any voltage at the light. Any suggestions?
Old 01-25-2011, 07:46 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
It almost sounds like a broken wire going to them.
Old 01-25-2011, 08:45 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
Does it only happen with the drivers door? Reason I ask is because there's a switch inside the door also that could be causing it. I'm going to wire mine up so it has a "dome override" like the chebbies.....
Old 01-25-2011, 10:10 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Here ya go.
Old 01-25-2011, 11:02 PM
wolfman08's Avatar
wolfman08 wolfman08 is offline
wolfman08 is starting off with a positive reputation.
Mine had similar symptoms when I bought it. Turned out that the drivers side door switch had apparently been stuck for so long that all of the courtesy light bulbs were blown including the bed light. That wouldn't explain no voltage though.
Is your door ajar light on?
Old 01-26-2011, 03:28 AM
thordehr thordehr is offline
thordehr has a good reputation on FTE.thordehr has a good reputation on FTE.
Here's what it was for me...
Old 01-26-2011, 07:27 AM
429 f-100's Avatar
429 f-100 429 f-100 is offline
429 f-100 has a good reputation on FTE.429 f-100 has a good reputation on FTE.
[ I'm going to wire mine up so it has a "dome override" like the chebbies.....[/quote]
i just unpluged the conn at the latch left side if i need the light just turn it on . the pass side works normal . this will also let you move windows after key is turned off . unless rt door is open .
Old 01-26-2011, 10:54 AM
WA.Ranger's Avatar
Quote:
i just unpluged the conn at the latch left side if i need the light just turn it on . the pass side works normal . this will also let you move windows after key is turned off . unless rt door is open . [/QUOTE]
That's exactly how I have it now, but I have three unused switches in my dash and I like the idea of the override. Wife drives the truck sometimes........
Old 01-26-2011, 11:02 AM
lostmybeer's Avatar
lostmybeer lostmybeer is offline
Have a nice Beer!!!
lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.
There is clip that may have come undone. Passenger side kick panel is where its located.
Sounds like a shorted headlight switch? IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 06-23-2014 08:00 PM
dome light stays on, no door ding, radio wont turn on mtinsman 1999 to 2016 Super Duty 2 05-22-2013 09:27 PM
Dome lights not working Spikebox 6.7L Power Stroke Diesel 6 10-11-2011 02:42 AM
Door ajar light is on dome light dont work auto headlights dont come on pjnadon 1999 - 2003 7.3L Power Stroke Diesel 18 08-26-2010 08:06 PM
Dome light wont turn off Darob 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-28-2007 05:22 PM
Tags
2000, 2001, 2004, dome, f250, f350, ford, imterior, interior, light, overhead, ranger, shut, truck, turn, wont, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
