Clutch HELP plz!
Old 01-24-2011, 07:51 PM
brownie83's Avatar
brownie83
brownie83 is offline
Question Clutch HELP plz!
hey guys..
tonite i was shifting and sheered off the pin on my clutch pedal that holds the clutch cylinder rod...i had to have it towed to a shop. it didnt feel tight or any different than normal, other than it was -11 this am and about 10+ when it broke.
first off...what would cause this? wear? old age? also how can i prevent it from happening? and do i need to buy a whole new pedal assembly or is the a cheap, easy fix from one of the brothers? thanks alot in advance...
chris
Old 01-24-2011, 07:55 PM
F350-6's Avatar
F350-6
F350-6 is offline
The cheap fix is to drill a hole in the pedal where the little shaft broke off and stick a bolt in there. There's an upgrade mod some do using a heim joint, but I'd have to try and find the link.
Old 01-25-2011, 07:27 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Old 01-26-2011, 07:24 AM
brownie83's Avatar
brownie83
got it fixed...
we ended up grinding off the "head" side and welding the pin back on. installed a nylon bushing and used a cotter pin...all is back to normal and the clutch actually feels better than ever...
thanks to those who threw out suggestions....
Old 01-26-2011, 07:46 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
timmy thanks for the link
ill be trying this while my dash is off
reps sent
Old 01-26-2011, 09:42 AM
timmyboy76's Avatar
timmyboy76
cool, thanks....and for audio/video...i know this guy is not very "popular" around here, but video can help alot.
YouTube - CLUTCH PEDAL FIX FOR FORD TRUCKS
AJHEATING
04-15-2022 10:29 AM
LeneliTanker
02-24-2015 10:24 AM
IDIDieselJohn
12-31-2013 04:15 PM
archangel
05-17-2004 12:01 PM
Quick Reply: Clutch HELP plz!
