1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
5 lug to 6 lug???????
Old 01-25-2011, 06:16 PM
limited4life's Avatar
limited4life
limited4life is offline
Talking 5 lug to 6 lug???????
Hello to all,I was wondering if I can change my wheel bolt pattern from my 2000 lincoln navigator 5 lug to the 2003 -2006 lincoln navigator 6 lug??
Old 01-25-2011, 07:16 PM
Londart's Avatar
Londart
Londart is offline
I work for an autoparts store and have had a few people come in thru the years wanting to do that with different vehicles....i have called the tire stores we supply parts to and sent them to them but they say its really not worth it if your just doing it because you have wheels with that pattern since they're really expensive as well...i'm sure they are available but whether or not theyre reasonably priced i dont know for sure
Old 01-26-2011, 08:26 AM
2trux's Avatar
2trux
2trux is offline
You can do most anything if you have the time, money, and skill. I converted my 69 Bronco to 8 bolt 3/4 ton to increase its durability. I narrowed a 3/4 ton Dodge van axle, and converted the rear to coil springs. For the front I replaced everything from the spindles out from a 3/4 ton Chevy pickup.
The first things to ask "Why do I want to do this? What am I willing to do to accomplish it?"
If you decide you want to do it start researching what it will take. It could be all you need to change is the axle shafts for the rear and the rotors for the front. It might also take swapping out the entire axle, or even changing the entire suspension or frame.
If you know someone with a Navi of the correct year you can do some comparisons. Don't expect much help from parts people because their computers will not show that the parts fit.
This could turn out to be a simple process of spending several hundred bucks and a weekend of bolting on parts, or spending several thousand bucks and months of fabrication.
Have fun, having something custom that no one else has is cool!
Old 01-26-2011, 09:45 AM
benningstspeed1.0's Avatar
benningstspeed1.0
benningstspeed1.0 is offline
they are avalible, i thought of doing the same thing to my navigator because i aquired a set of 22" wheels (free). From what I have found they are like $100ea. I decided for $400 + what I can sell the wheels for. I can just buy some nice wheels and not have adapters.
Old 01-26-2011, 11:08 AM
2trux's Avatar
2trux
2trux is offline
I don't think that I would take a chance on hanging my tires on a set of adapters. After having seen wheels shear off the studs, and snapping axles, I would not put in a new point of failure.
SapperJoe
01-24-2017 10:48 AM
kameronth
07-30-2014 10:58 AM
robjs111
02-07-2011 05:30 PM
mattjensen
04-24-2009 04:28 PM
AKTraveler
1978 - 1996 Big Bronco
05-09-2003 07:54 AM
Quick Reply: 5 lug to 6 lug???????
