Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 01-25-2011, 05:56 PM
radramrod2 radramrod2 is offline
Garage is empty, add now
radramrod2 is starting off with a positive reputation.
Mercon V in 4R100?
Getting conflicting information about what to use in my 99 F250 LD 4R100. The dipstick says Mercon and I'm being told Mercon V is now acceptable to use according to a Ford TSB?
All I want to know if it's ok to drop the pan, change the filter and replace the lost fluid with the new Mercon V? While leaving the old fluid in the cooler lines? I'll drain the TC too. Or should I just stick with the Dexron III/Mercon blend?
Rad
  #2 (permalink)
Old 01-25-2011, 06:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
use the Mercon V, not dextron III
http://www.aa1car.com/library/ford_tsb_06144.pdf
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
Tags
2003, 2004, 4r100, diesel, f250, ford, mercon, mercron, slip, super, switch, tech, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
