Set of OEM 8 lug, 17" Alloy Rims, 99'-04' - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Closed Thread
Old 01-25-2011, 09:09 AM
knuckleheadnut's Avatar
knuckleheadnut knuckleheadnut is offline
knuckleheadnut is starting off with a positive reputation.
looking for a nice set of FORD OEM 17" or 18" alloy rims that came off a 99'-04' F250/350 or Excursion to use on my daily driver. No cracks or missing chunks or other significant flaws. Should have 4.25-4.5" back spacing, 8-9.0" rim width (?) and 8 on 170 lug pattern. So go get those old take-offs out of the shed and pocket some mod funding. thanks for looking.
Old 01-27-2011, 12:43 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
FYI these years all had 16" wheels, except for a few 04's that got 18's. You probably need 05-up to get 17" wheels (same bolt pattern, but I'm not sure about the offset).
Old 01-27-2011, 07:36 PM
Chief66- I thought 17s were an option in '99-'04? I know the '05 and later have more offset and require spacers to fit earlier. Don't want to go there. thanks.
I guess there were no 17" between '99-'04. Must have been the Harley Edition that got 18"??? or were they 20"s?
Were all the 16" wheels for that period 7" rims. Or was there an 8" rim offered for F-350s? If only 7"s, then the tallest tire you can safely run is 265/75... which is the stock size I have now on my stock 7" rims. All the tire companies call for minimum of 7-1/2" rims for a 285/75. The 265s buldge out enough as is.
So it seems it's after market only for oversize (larger than 265s) wheel/tire combos for the '99-'04s. Unless you use spacers on '05 and later 17"+, which I won't do.
Old 02-05-2011, 07:11 PM
Midnight Sun Midnight Sun is offline
Midnight Sun is starting off with a positive reputation.
man i ran 305 70 16 on my factoryrims for 3 years befor i bought som 8in after market rims now i run 35's on them
Old 04-15-2011, 09:42 PM
SHANE_2 SHANE_2 is offline
SHANE_2 is starting off with a positive reputation.
I have a set of 18" King Ranch wheels with 275/70/18 continental TR on them. They have about 6k miles on them. I'm asking $1000 for them. They are polished with tan inserts
Shane
Old 04-19-2011, 12:00 AM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
I have a set of 17" Micky Thompson Classics that I took off my 2000 Ex when I put new wheels on. They have 305/70R17s on them right now but they are pretty much done for. The wheels could stand to be polished but are clean and straight with no nicks or scratches. Let me know if you are interested.
Here is a pic:
EDIT: Just saw how old the original ad was. I have the, for sale for anyone else that comes along but it looks as the OP has already procured some 17s
Closed Thread
18" Spare for my 2000 Excursion? mykels Excursion - King of SUVs 6 12-02-2014 07:53 AM
01-04 Lightning Supercharger Kit robjs111 Ford Truck Parts for Sale 2 11-30-2014 09:05 AM
WTB: 99-04 - 16"x7"-8 lug Bright Polished wheel JTATMAN WTB - Parts & other 0 09-22-2014 08:49 AM
ISO: 99-04 OEM 16"x7" - 8 lug wheel JTATMAN WTB - Parts & other 0 09-20-2014 08:41 AM
ATX Slot wheels and swamper m16 tires High Intentions Ford Truck Parts for Sale 2 01-23-2014 04:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
17, 18, 1980, 2003, alloy, aluminum, bolt, f150, ford, lug, oem, rim, rims, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
