'99 F-150 2wd pulls to the right when braking. - Ford Truck Enthusiasts Forums
Old 01-25-2011, 08:31 AM
tdbt3c tdbt3c is offline
tdbt3c is starting off with a positive reputation.
I had a posting a few days ago about this, thanks to all that helped. Sadly I must say the problem isn't solved. Even the mechanics at the local shop couldn't figure it out. Here's the situation:
When driving normal, I can take my hands off the wheel and the truck runs true, aligned well. But if I hit the brakes, the truck wants to pull to the right. It doesn't do it bad, if I have my hand on the wheel I don't even feel the tug. But I guess it's too much to pass inspection.
Here's the history:
Spring '09 - new tires all around (15K highway miles since)
Summer '09 - turned the front rotors (disk brakes) and new pads all around.
Summer '10 - New rotors and brake pads on the front. One front rotor had eaten the brake pad down to the rivets and gouged the rotor, so I put brand new one's on. Also new brake pads then.
Now - Brand new calipers and brake pads on the front. Found a broken linkage on the sway bar and replaced (thanks guys), but the problem still exists.
My ABS light is on, and the dealership said my front wheel speed sensors aren't reading properly. They blamed the new rotors, saying they may be the wrong size.
Any ideas
The local inspector failed my inspection, handed me my keys and said "good luck". My tags expire at the end of the month!
Old 01-25-2011, 09:41 AM
MIKE 04 GT MIKE 04 GT is offline
MIKE 04 GT is starting off with a positive reputation.
next i would change the rubber brake hoses. sometimes they will swell and not let the brake flude flow trough them
Old 01-25-2011, 10:12 AM
Thanks Mike. That's funny, the mechanics blamed the hoses saying that the pigtail in the hose between the hardline and the caliper might be to blame. I'll swap the hoses ASAP. Unfortunately, my hard lines are so rusted, I'll need to go ahead and replace those too, or else I know they'll break while I try to attach the rubber hoses. Just my luck.
Any other thoughts???
Old 01-25-2011, 04:55 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Your left front hose is likely collapsed.
Old 01-25-2011, 05:22 PM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
Air pressure in the tires exactly the same ? Maybe diameter of the front tires slightly different ?
With all that work on the front end, the ABS sensors may have bent bracket (s). The sensor air gap I think is around .050. I'd check the left front sensor first for damage, bad harness, rusty particles on the end of the sensor.
Dave
New calipers; brakes still pull left Im50fast 1968-2013 Full Size Vans 50 09-17-2016 08:08 PM
Brake problem or something else? fordmustangfan67 1999 to 2016 Super Duty 9 08-03-2015 09:54 PM
front brakes dragging ' F350 58k rick52 1999 to 2016 Super Duty 7 10-25-2011 09:42 PM
Brake Rotor Problem DemonRace6 1999 - 2003 7.3L Power Stroke Diesel 15 04-20-2011 02:34 PM
Problem with Brakes...crazy Vibration Uprising 2004 - 2008 F150 6 02-06-2011 10:09 AM
Tags
2wd, 99, abs, brake, braking, break, driving, expedition, f150, f250, ford, left, pad, pulls, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
