Anyone get rid of 6.0 dpowerstroke for the new 6.2?
I currently have a 2006 F350 6.0 but, I'm interested in the 6.2 gas. I was wanting to hear from guys that have made the change from the 6.0 if their happy with the new gas motor...any regrets or if anyone has gone from a Chevy 6.0 to the 6.2, I've had both so any comparisons would be great.
I did try to do some search's but came up with not a lot of info on this subject....thanks for any help and info.
Good question. IIRC, I've read a couple of posts on here from folks who made the switch from the 6.0. I am interested as well so thanks for asking.....I'll be watching for responses. In the meantime, here's one you may or may not have read from a former 6.4 owner who switched.
https://www.ford-trucks.com/forums/1...-to-6-2-a.html
I have a 2006 F350 6.0 and wanting to get peoples thoughts and any info of going to the 6.2 gas after having the 6.0 diesel. I tow a 8000 pound trailer about 10 times a month and would like to know how it will perform and what rear end to get? Thanks
What kind of terrain? The same load in Florida is a LOT different than even where I live, lots of rolling hills. Going even more mountainous, and it makes a difference. For what it's worth, the engine in this truck has more horsepower than any previous PSD that ford has offered. The new 6.7 is only a few hp higher. The real difference is the torque, but these transmissions are geared fairly well, with a good steep 1st gear-so getting big loads started is not such a chore. I can only speak from experience of about 5-6,000 lbs towing with this truck so far, but I can assure you, I practically forgot the trailer was behind me. If you are in a position where you have the financial ability to switch to a new truck, I honestly do not think you would regret it. Just my 2 cents.
Thanks Claycomotrucks1991, what rear end gear did you go with? I assume your in the Kansas City area, so what rear end gear should I go with? My trailer is a tandem axel flatbed with a pressure washer, 525 gallon water tank and misc. other stuff mounted on it that I pull from commercial job to job, about 50/50 of city and interstate. I've heard 373 will be fine than others say get the 430 and with the 6 speed it will make up the fuel economy...any thoughts or advice would be greatly appreciated.
The info that has been given is great. I was considering the diesel but ended up with the 6.2 and am very happy with it. I haul a enclosed 102" X 20' Car carrier with full carpentry workshop in it about #7000. Hauling this load in the mountains of VT is no problem. I average about 9mpg and I can't be happier.
Got rid of my manual 2006 CC LB 6.0L. Have the 6.2L 3.73. Tow trailer about your size, usually at 80mph if I am in a hurry.
If towing lots, would have gone 4.30. But I mostly run light or with a smaller enclosed snowmobile trailer. I live at 7,000 ft elevation and run up and down the mountain.
I am quite happy that the 6.0L is gone, and am ok that my fuel econ is down 25% from my old 6.0L. Like the gas motor much better for lots of reasons....
Glad I found you guys
I have a 03 F-250 CC, 4x2, LB, Lariet, 5th wheel receiver, sprayed in bed liner, Royal Red/Pale Adobe with the 6.0L Powerstroke and just a fewhours ago I ordered my new 2011- F-250 SC, 4X2 with the 6.2L gas. It has the standard 3.73 rearend and I pull a 9,000 lb 5th wheel one a month.
Like others have said the diesel prices are way up and even though I love my 2003 6L it was time to get back to gas and save a few buck on fillups.
They say it will be 6-8 weeks to get. Anyone have any pictures of that 2 tone color? Royal Red/Pale Adobe?
