1977 crewcab cummins build - Ford Truck Enthusiasts Forums
Old 01-24-2011, 12:12 PM
77_crew's Avatar
77_crew 77_crew is offline
77_crew is starting off with a positive reputation.
Hi all, I'm new to the thread posting but i thought that i'd share my project with you. I've been reading other threads about people doing a similar build. Heres what i started with, I picked up a 77 crew 2wd short box that someone had put a 79 grill on.
Old 01-24-2011, 12:22 PM
77_crew's Avatar
Here she is.
Old 01-24-2011, 12:28 PM
77_crew's Avatar
The PO had installed a olds 455 rocket, so that had to go... i began searching for a cummins turbo diesel. After several weeks i found a first gen that was in a 1990 w250. A friend and i split on the truck because he wanted the drive drain and tranny, and i wanted the engine.
Old 01-24-2011, 12:41 PM
77_crew's Avatar
As well as the cummins conversion, i planned on doing a 4x4 conversion. I have quite a few 4x4 axles and parts, but all dana 44s and dana 44hds. With the weight of the cummins i figured that i needed a 60 up front. After a long search i managed to buy a 1979 F250 snowfighter for 500 bucks!!! What a score!!!
Old 01-24-2011, 04:44 PM
73FordF100's Avatar
73FordF100 73FordF100 is offline
73FordF100 is starting off with a positive reputation.
Great thread so far! Keep us posted on the progress !
Old 01-24-2011, 05:10 PM
impalaslayer's Avatar
impalaslayer impalaslayer is offline
impalaslayer is starting off with a positive reputation.
that super cab looks pretty rotted out, thats too bad. atleast it will get you some needed parts. im keeping the d44 under my cummins. keep the pics coming and check out my build. doing the same thing with a regular cab
Old 01-24-2011, 05:22 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
looks like a fun project - welcome to the crew cab/cummins club
Old 01-24-2011, 05:23 PM
77_crew's Avatar
Atfer getting the matched set of 60s from under the snow fighter i had to decide what i was to run for gears. My crew had a dana 60 with 3.55 gears, and the snow fighter axles had 4.10s. I decided that i would go with the 4.10s after doing a little calculating, seeing that i was going to run a taller tire. The next question was what rear 60 was i going to use. I had noticed that my crew frame (2wd) was almost identical to a 4x4 hi-boy frame (with the exception of some crossmembers) with the narrow rear frame. That meant that my new 4.10 60 was not going to be a bolt in.
Old 01-24-2011, 05:26 PM
the difference is spring pad location. With your talk about converting to 4wd and a cummins this should be no sweat for you...
Old 01-24-2011, 05:28 PM
77_crew's Avatar
Thanks Chasetruck74, i've been reading your thread and you have a pretty cool machine in the works.
Old 01-24-2011, 05:30 PM
i plan on running the stock 410s in mine with 35 inch tires. i have a zf5 im backing it with and the OD is .76 IIRC. that puts me at about 65mph at 1800 IIRC. it was about perfect for me.
Old 01-24-2011, 05:37 PM
77_crew's Avatar
you are right, i've done this many times before, but my original axle appeared to be much cleaner, in better shape, it had more gussets on the pumpkin, so i decided to swap the 4.10s into it. When i did this i also installed a detroit/eaton tru-trac.
Old 01-24-2011, 05:39 PM
77_crew's Avatar
impalaslayer, i also am running a zf5 with a destroked adaptor, so my numbers are simmilar to yours...
Old 01-24-2011, 05:41 PM
Quote:
nice, i got my adapter from a van, didnt wana shell out the cash for the destroked if i didnt have to
Old 01-24-2011, 05:45 PM
77_crew's Avatar
i know it was expensive, i was going to machine my own, but i was just too busy... i am millwright by trade and have my own machine/fabrication shop.
1978-1979 Crew Cab build thread 1KILLERZ 1973 - 1979 F-100 & Larger F-Series Trucks 248 Today 03:40 PM
77 highboy build- Project Winter Truck 77_crew 1973 - 1979 F-100 & Larger F-Series Trucks 156 10-13-2016 08:51 AM
3"-4" lift with highest GVW Rtbcoop 1973 - 1979 F-100 & Larger F-Series Trucks 19 04-20-2016 07:54 AM
OT a little, but it's a Ford truck... Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-07-2015 06:13 PM
What years did they make 6th generation crew cabs? DasCheckers 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-13-2010 08:13 PM
Tags
1977, 1978, build, cab, crew, cummins, diesel, engine, f250, ford, inc, installing, long, parts, site, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
