1977 crewcab cummins build - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 04-11-2011, 05:39 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Looks like a cool mount - can't wait to see how you attach it to the truck.
*edit* that last post came in before I hit reply on this - looks like a cool setup!
  #62
Old 04-11-2011, 05:44 PM
77_crew's Avatar
77_crew 77_crew is online now
77_crew is starting off with a positive reputation.
Thanks, its 24" wide so i will probable notch the crossmember gussets and inset it into them close to the crossmember, then burn it in there.... i'm hoping that leaves me with a good set up fo all three drive shafts.
  #63
Old 04-11-2011, 05:48 PM
77460ford's Avatar
77460ford 77460ford is offline
77460ford is gaining momentum as a positive member of FTE.77460ford is gaining momentum as a positive member of FTE.
Where did you source your bushings? Really like the look of the mounts, I might need to borrow your design to mount my gear splitter.
  #64
Old 04-11-2011, 05:52 PM
77_crew's Avatar
I also got my parts front clip home that is holding the rad i want to use, and the mint grill i want to use as well. After alittle inspection i decided that i will use the rad support, the rad, and the grill. I will use my original inner fenders and fenders i think.
Heres my original. the truck is a 77 but the previous owner converted it to the 79 grill...
  #65
Old 04-11-2011, 06:01 PM
77_crew's Avatar
I got the bushings from a friend that sells industrial equipment parts. He had some extras kicking around... i'll ask him where he gets them and let you guys know.....
  #66
Old 04-11-2011, 06:04 PM
77460ford's Avatar
Appreciate that, Thanks!
  #67
Old 04-17-2011, 08:48 AM
77_crew's Avatar
well, more progress made... my buddy and i pulled the truck ot of its tent and began installing the T-case... I notched the crossmember gussets to fit my 24" wide plate in, then I took two pieces of heavy wall 1"x1" square tubing and welted them to the underside of the crossmember. The next job was welding the mounting plate to the 1" tubes. I measured from the plate to the rear axle to be sure that it was square (not that this matters because the driveshafts would allow for misalignment). Then i burned her in there. the next hurdle was lifting the heavy t-cse into place. This would have been not so bad if my floor jack hadn't screwed up the day before. So it was bench press time....after alittle sruggling, the 4 bolts slid in and there she was.
  #68
Old 04-17-2011, 09:23 AM
impalaslayer's Avatar
impalaslayer impalaslayer is offline
impalaslayer is starting off with a positive reputation.
trans x member looks beefy, but why did you have to change it?
  #69
Old 04-17-2011, 09:26 AM
77_crew's Avatar
After a couple of well deserved beers we began to check out our final poduct. At a first glance the case appeared to be hanging pretty low. Atfer a few measurements on my 77 F250 highboy (reg cab, long box, 460, C6, and the divorced t-case is in its stock location) thats sitting in my backyard, my case was only 1" lower than the stock location...sweet.
i then began to take some driveshaft measurments. My front DS will be around 50" long, the rear is 58" long, and the input shaft will be around 18" long.
  #70
Old 04-17-2011, 09:31 AM
77_crew's Avatar
Quote:
The truck started out as a 2wd so never existed to begin with. the crossmember i mounted it to was where the hangerbearing was.
  #71
Old 04-18-2011, 12:31 AM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
nice build i am jealus
  #72
Old 04-18-2011, 10:21 AM
Quote:
good reason! lol looks good man
  #73
Old 04-18-2011, 09:47 PM
77_crew's Avatar
Thanks for the compliments guys, it feels good to make some progress.
  #74
Old 04-18-2011, 09:59 PM
77_crew's Avatar
I got the rad support cleaned and painted, then i mocked it up on the truck so i could set my rad in to check for clearance between the fan. It looks perfect. Around 1" of clearance should be fine.
  #75
Old 04-18-2011, 10:11 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
That fuel cell is really nice. I gotta learn to weld aluminum.
1978-1979 Crew Cab build thread 1KILLERZ 1973 - 1979 F-100 & Larger F-Series Trucks 254 03-06-2017 01:15 PM
77 highboy build- Project Winter Truck 77_crew 1973 - 1979 F-100 & Larger F-Series Trucks 156 10-13-2016 07:51 AM
3"-4" lift with highest GVW Rtbcoop 1973 - 1979 F-100 & Larger F-Series Trucks 19 04-20-2016 06:54 AM
OT a little, but it's a Ford truck... Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-07-2015 05:13 PM
new to bc chapter aironly British Columbia 3 01-10-2008 08:38 AM
Tags
1977, 1978, build, cab, crew, cummins, diesel, engine, f250, ford, inc, installing, long, parts, site, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
