fuel gauge slow to rise? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-24-2011, 11:58 AM
chelag204 chelag204 is offline
chelag204 is starting off with a positive reputation.
i have a 03 f250 v10, the problem i have is that when i went to fill up the tank, the fuel gauge still said empty. after driving around a bit, it started to rise up gradually, up to about 3/4 full. i only went 12kms and i asked for a fill, so i dont think thats where my reading should be. has this ever happened to anyone?
btw, the temp here is avg-40right now
Old 01-24-2011, 12:21 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Very common issue on the 6.0, and I don't imagine the programming for the fuel gauge is remarkably different on gas engine SDs, here's the thread:
http://www.ford-trucks.com/forums/51...ml#post3823994
Old 01-24-2011, 03:05 PM
TXHillCountry's Avatar
TXHillCountry TXHillCountry is offline
TXHillCountry is starting off with a positive reputation.
On my '03, if you either leave the truck running while filling, or even just leave the key in the "accessory on" position while filling, it does the same thing as you describe every time.
It eventually "gets right" after driving a day or two.
TX
Old 01-24-2011, 03:09 PM
I went to top it off today and it put $25 worth of gas...I was wondering why it was only 95 the other day.
ontariofarmer's Avatar
ontariofarmer ontariofarmer is offline
ontariofarmer is gaining momentum as a positive member of FTE.ontariofarmer is gaining momentum as a positive member of FTE.
My truck does the same every now and then, I just give it about an hour, and everything is good again.
Old 01-24-2011, 06:06 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
Sometimes high sulfur fuel will screw with the sending unit. I thought I read a thread where someone pulled it out and cleaned it somehow. The guage on my '08 reacts slow, but it is only about a 5 min. to 10 min. delay at worst.
Old 01-24-2011, 08:08 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
put a couple of cans of good quality fuel treatment/cleaner into teh tank when yuor fairly low on fuel...
my truck was doing the same thing back about a year ago, since doing this my trucks guage has been spot on since..
hope that helps..
ps yea it is kinda common for this vintage of truck to start having issues with teh guages due to buildup on the float level.
Fuel gauge rises slowly after fill ford-lover 2004 - 2008 F150 13 01-09-2016 10:15 AM
new to the forum with a fuel tank question Ajax 1 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-04-2015 02:07 PM
Fuel gauge not working! Idlewild24 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-04-2014 12:55 AM
02 F350 Getting 5mpg drus136566 1999 to 2016 Super Duty 16 02-02-2013 10:54 PM
96 F-150 thermostat MFogarty1996 1987 - 1996 F150 & Larger F-Series Trucks 6 03-04-2011 07:33 PM
Tags
150, 2005, f150, f250, ford, fuel, gas, gauge, guage, respond, responding, rising, slow, top, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
