Wiring diagram for power window system
I was playing with the power window wiring in a 94 Exploder, trying to disable the annoying one touch auto down feature. But the wiring diagram in the Haynes book doesn't match what I see in the vehicle--Haynes shows 6 wires on the one touch module, when in fact there are only 5, and the colors are all different. Anyone have an accurate diagram?
Interesting, most people wish more windows had the one touch feature. Does the '94 have the second detent for the one-touch, or does it default to one-touch and you have to press the button a second time to stop the window in process?
Which wiring diagram are you using so I don't waste my time checking EBSCO if you've already used that one?
-Rod
-Rod
I can't stand any electronic system that tries to guess what I want and do it automatically; all too often it gets it wrong.
There's no second detent (that would seem like a much better system); I just push the down button and it goes all the way down unless I push the up button.
Does your one-touch module have wire colors red, red/yellow, light blue/black, yellow/red, and black? If so, it looks like you should unplug the one-touch module and jumper the red to the red/yellow wire. That should will take the one-touch module out of the circuit and should allow the window to function "normally".
The light blue/black wire is fused feed and the black wire is ground.
-Rod
-Rod
