Fuel tank selector valve replacement, and fuel gauge - Ford Truck Enthusiasts Forums
Old 01-23-2011, 04:44 PM
yomadmike's Avatar
yomadmike yomadmike is offline
yomadmike is starting off with a positive reputation.
I bought my wife a 1978 F250 Camper special with 69000 original miles on the 460. Long story short, the electronic tank selector valve was in a bag on the floor when I bought it and the main tank is the only one hooked up. The previous owner unhooked the aux tank. I want to hook this all back up the way it came and I have a question. Ford doesn't make this part anymore, and I found this online: Electric Tank Switching Valve - WILD HORSES Early Ford Bronco Parts
It looks correct but I need some informed opinions. My tank selector switch is on the dash by the heater controls. Also will replacing this switch make the fuel gauge work again as the previous owner states? I've always been a Ford guy and I own a 99 Mustang Cobra vert, but this is my first endeavor into carburated vehicles, and my first F series truck. Anyway, any help is greatly appreciated.
Old 06-06-2014, 07:02 PM
uncle louie uncle louie is offline
uncle louie is starting off with a positive reputation.
Exactly the same subject matter I am trying to deal with today 06-06/2014. Nothing like awakening the dead to start a relationship.
Any help would be appreciated thanks.
Old 06-06-2014, 07:32 PM
yomadmike's Avatar
I bought the part in the link. Hooked right up and works great 3 years later.
Old 06-06-2014, 07:40 PM
From what I understand the above switch it is a one wire connection, my 78-F250 has two wires connected to the stock tank switch. Question is will connecting a single wire to this part allow the fuel gauges to switch and work properly? '' This is the stuff only dreams are made of ''
Old 06-06-2014, 08:35 PM
yomadmike I cannot send a PM for ten days, but I am some what good with that and still hoping my answer will soon be posted here.
Thanks in advance
Old 06-06-2014, 10:20 PM
yomadmike's Avatar
On my wife's 78 it was only a one wire hook up. Everything works just like it should. Does your tank switch look exactly like the one in the link? If not, it may have been replaced once already.
Old 06-06-2014, 10:34 PM
PDX_350's Avatar
PDX_350 PDX_350 is offline
PDX_350 is starting off with a positive reputation.
Uncle
Not 100% sure this answers your question but i'll give it a shot.
This wiring diagram is for a 79 but it should be the same. Top center of the page is the fuel selector dash switch to control the gauges AND the electronic valve. It shows one wire to the valve and grounded through the frame.
In one switch position it's in neutral (no power, spring loaded to the default tank) in the other position it is powered to push the valve to the other tank.
Is it possible someone added a ground wire to your selector valve? All the ones i've seen have one wire and the factory wiring diagrams show one wire.
I'm in the process of upgrading my 73 from the factory manual selector to a 79 electric as part of an overall electrical upgrade so i've been spending a lot of time with these pages.
Hope that helps.
Old 06-07-2014, 12:57 AM
OldMetal's Avatar
OldMetal OldMetal is offline
OldMetal is gaining momentum as a positive member of FTE.
Thanks for the link, im going check it out and buy a switch just so i have a spare
Old 06-07-2014, 09:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assy / Obsolete
D5TZ-9A050-A .. Fuel Tank Selector Switch / Available from Ford ~ MSRP: $37.78.
Applications: 1975/79 F100/350.
The switch changes the tanks and the dash fuel gauge from one tank to the other.
Old 06-07-2014, 06:33 PM
OldMetal's Avatar
ND, is that the part number for the dash switch or the in line solenoid?
D5tz 9a050 a ?
Old 06-07-2014, 10:47 PM
Quote:
Originally Posted by OldMetal
ND, is that the part number for the dash switch or the inline solenoid? D5tz 9a050 a?
Doesn't this post make it clear which is which?
Old 06-07-2014, 11:52 PM
OldMetal's Avatar
Sorry i asked, terminology and part numbers can be confusing
Old 06-20-2014, 10:52 AM
Quote:
Originally Posted by PDX_350 View Post
Uncle
Hope that helps.
PDX-- Thank you for your effort :} Going through all that you provided is involved and very time consuming, to post the wiring diagram and to comment on my problem as you have is very well appreciated and has not gone unnoticed.
My project load is overwhelming considering the number of old rigs we own. The thing is I love wrenching and sooner or later things come full circle and get repaired. This switch is a learning process currently, as I repair some hydraulic problems on my 1985 Case 580 Super E Back Hoe, problems that occurred last winter during our rainy season.
I have no roof so wile the sun is shining the tools will be out doors staying dry as I continue to repair things one at a time.
Next is the complete air conditioning system replacement in my wife's vehicle.
As I review the dash switch and try to determine what the second wire is on the factory frame rail fluid switch, for the 1978 F250 custom cab 4x4, I will keep this forum up dated.
What once took a few hours may now take a few days but if not for the oil in my veins my heart would have quit a long time ago.
Thanks
Uncle Louie
PS - PDX It is raining out there or I would have a look at the lower [2nd] wire. As soon as I can get around I will have a look to see if there is a boot covering the connection to the lower wire on the fluid switch. It all looked factory to me but I am the 2nd owner having made purchase in the very early 1980s.
Old 06-20-2014, 01:20 PM
The top wire is light blue going into the top of the liquid switch through a factory rubber compression retainer. The second wire is white with a white stripe, going into a factory clip connector that is mounted to the center of the motor drive mechanism which is located in the lower half of this part.
So absolutely yes there are two wires involved in the original 1978 F-250 Ford dual Gas tank selector switch and valve.
Uncle Louie
Old 06-20-2014, 02:30 PM
NEED HELP! Selector Valve Trouble! newrevnorton 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-30-2016 02:25 PM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
Fuel Gauge Open Circuit Diagnostics Help Franken-Truck Electrical Systems/Wiring 2 12-18-2011 07:20 PM
fuel gauge/tank wiring mouse80 1987 - 1996 F150 & Larger F-Series Trucks 0 05-23-2010 09:51 PM
Fuel Selector Valve? 1986 F-350 w/460 mdm350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-16-2010 10:52 PM
Tags
1979, 73, bronco, f250, ford, fuel, removing, replacement, replacing, selector, selevtor, switch, tank, tru, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
