Fuel tank selector valve replacement, and fuel gauge - Page 2 - Ford Truck Enthusiasts Forums
Old 06-20-2014, 03:34 PM
rougeriver rougeriver is online now
rougeriver is gaining momentum as a positive member of FTE.
Congrats on finding that NOS part!
David
Old 06-20-2014, 08:02 PM
uncle louie uncle louie is offline
uncle louie is starting off with a positive reputation.
Quote:
David
Thanks rougeriver -
The Coquille River runs between us.
Two wires and two bolts maybe it will last another thirty seven years as this old 1978 F250 custom cab 4x4 sold in the summer of 1977
Uncle Louie
Old 06-23-2014, 05:21 PM
PDX_350's Avatar
PDX_350 PDX_350 is offline
PDX_350 is starting off with a positive reputation.
Uncle Louie,
Nice find on the NOS part and the difference in wiring by one year doesn't surprise me much.
Ouch on the sticker price though - but what can you do. I know there isn't much in the way of parts vehicles over on that edge of the state either.
And who cares if it takes hours, days or weeks as long as you enjoy doing it. Keep the oil level on the mark in that blood stream and we will see you around.
Old 06-24-2014, 11:00 AM
PDX-350
Yes the part was priced a bit on the high side but when I considered the installation procedure. The level of effort to remove and replace the OEM part was so much simpler than reconstructing the entire circuit. I was ready to do that but this was like finding money where time is any consideration.
So far the steel return line to the backhoe loader bucket has been removed cleaned, braised, primed and re installed. The compression fittings were in a tight spot between the frame, took a good deal of the machine apart just to get to it. After braking several tools during the removal process, it is now working perfectly. The hoe section is greased, and today the bucket section and undercarriage will get done. Then the hydraulic cylinders that have gotten to be more than a drip will be taken care of next. The air conditioner for my wife's car has not yet arrived, looking forward to getting that replaced.
So many things to do, that O E M - Gas Tank Selector Valve with Solenoid was a steal at any price. There is a full tank back there about $80.00, I need to use it up.
Later
Uncle Louie
Old 06-24-2014, 08:28 PM
PDX_350's Avatar
I totally get where you are coming from. When you are that busy it's like buying time.
Take care.
NEED HELP! Selector Valve Trouble! newrevnorton 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-30-2016 02:25 PM
Pollak Light Truck 6-Port Motor Driven Fuel Selector Valve= no fuel gauges FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-11-2016 08:54 AM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
Installing Electronically Controlled Fuel Tank Selector Valve 1988 Ford F150 Matt Cherry Fuel Injection, Carburetion & Fuel System 2 06-27-2014 06:00 PM
Tank selector valve/sending unit Heesman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-05-2014 06:51 AM
Tags
1979, 73, bronco, f250, ford, fuel, removing, replacement, replacing, selector, selevtor, switch, tank, tru, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
